Use an old laptop as a second desktop display
DSC_0020s
When we’re trying to get a relatively complex project to work we often end up with twenty windows open. When this happens we’re usually referencing multiple data sheets, webpages, and trying to write code that the same time. We’ve seen people with two or three monitors to alleviate the situation (often called a battlestation), but the we’re cheap and can’t justify buying more displays just for these occasions. Well [Oscar] may have the solution for us. His old laptop had been sitting in a box unused so he flipped the screen and built a stand to position it as an additional display on his desk.
The hack simply removed the screen for the hinged cover so that it could be flipped around. This turns the laptop into a tablet minus the touchscreen ability but that could always be added in later (we’ve seen it done with netbooks). He tells us that the only issue he ran into during this process was the length of the inverter cable. He simply cut it and spliced in a little bit of extra length.
[Oscar] didn’t write a post about his project, but you can see the build gallery after the break.
Comments
  1. jbgieu says:
    Is it really a second display ? I don’t think so. It’s just an other pc in your desk.
  2. Hybridchemistry says:
    So, does the laptop just run VNC or some remote desktop client to extend the desktop? Or did he find an easy way to use the laptop LCD as a monitor? AFAIK you typically need a specific bit of hardware to run the LCD, unless laptop monitors these days are connected via a micro VGA/DVI cable…
  3. riycou says:
    Pretty cool. Good idea are you going to make the HDD and Dvd drive network accessible? Extra storage it always a plus.
  4. ka1axy says:
    I did this to make a picture frame. It runs DSL off a flash card. Network connected and pulls images from a network drive.
    Old laptops are beginning to have enough power to be useful now…
  5. papagna says:
    And now… name the anime character!
  6. Matthew says:
    Im guessing this isnt physically a second display but instead some kind of second display software which works over the network. Or just using it as a second computer entirely
  7. DRNOS says:
    My battlestation is fully equipped.
    I have one primary fancy display and three 17″ LCDs picked up from goodwill for no more than $12 a pop. Auxiliary displays don’t need the greatest resolution or refresh time, so old ones work great.
  8. Rachie says:
    I don’t know where you get old laptops to experiment with. Mine always mysteriously die on me, well past the point of fixability.
  9. Super Brain AK says:
    i wonder if i would be able to take some old pentium III’s with bad hdd’s and hook up the display to my main computer. ive got like 5 of em and would like to have the extra screen space. mby put some kind of linux on and hook em up through usb or physically take out the creen and wire up a controller for em. just pondering…
  10. Karl says:
    All I can see here is that he flipped his laptop’s screen around and made it’s inverter cable a little bit longer. It also does not look too good.
    Although I respect his work and the fact he is trying to hack new and useful things out of something completely useless to him, I do not think it is exactly a Hackaday material.
    I mean, when I read the title I hoped to read about how he managed to make the screen from his old laptop to work as the second screen for his other computer.
    Did he design a VGA to LVDS adapter? Or maybe he is still booting up that old laptop and using some kind of VNC hack to extend his desktop over the VNC connection to another computer?
    And after reading this article, the answer is: I do not know. In fact, it is actually impossible to tell if he even is using that modified laptop to extend his desktop or just flipped the screen and using it as a completely independent system with USB keyboard and mouse.
    I probably would have accepted this hack even if he had a build log with pictures or even if the result looked really cool. Unfortunately there is no info of any kind on how it was done.
    I mean no offence and I think it is great and all that he made this screen and it is probably very useful to him, but in my opinion, if you are going to share your work with others, you should also share how it was done and what make makes it special (besides the fact that you built it, that is).
  11. Dynamo Dan says:
    I also like to use old laptops as dumb terminals off my lab server which is ubuntu 12.04 with 16GB ram. I run TigerVNC server/client and it works great with old windows 2000 machines as dumb terminals. TigerVNC has bindings for VirtualGL which allows full 3d on the clients, using the GPU of the server.
  12. I used to do this a lot. A program called MaxiVista extends your desktop onto your laptop, dunno if there’s better/free out there or if it still works well but when I was in college it’s what I used. Was great for having a spreadsheet and lab report both visible at the same time.
    If you don’t need your “main computer”‘s display extended, but just to be able to use two screens, Synergy lets you move your mouse between systems’ displays (as though it were two monitors on one system) as basically a KVM over LAN. You can also have a button (scroll lock, etc) switch which system you’re controlling like a traditional KVM.
    Both of these programs worked way more reliably over wired LAN than with either/both systems being on Wifi.
  13. cololoco says:
    As a display? We did the opposite and used an old laptop as a co-lo server – for years.
    It was so good that it managed to roll over the Linux uptime counter at least twice.
    All on the internal disc. And it didn’t use much power.
  14. Nephillim says:
    There is also Input Director and Microsoft’s Mouse without Boarders
  15. ddt says:
    Wow, this is a terrible HaD post. This may be a hack but it’s so common place that it doesn’t need a new post, especially a post without details or a write up… Shame on you Mike.
  16. dooglehead says:
    You can buy a board that connects lcd screens with vga/dvi for around $35 on ebay. I used that to build a monitor out of an old laptop screen. http://i.imgur.com/Cr7B2.jpg
  17. polossatik says:
    ok, advantage : it’s free
    disadvantage: it takes relative hughe amount of space and most laptops have low res shiny screens.
    Using a old laptop ( and ceetainly desktop) as “extra” screen also uses rather a lot of power for nothing and add noise (fans, HD etc).
    A new low/midrange screen hardly costs anything anymore, if $$ is the real factor try to get some dead screens who are going to be junked made about 4 to 5 years ago, i think 99% of those died due bad caps.
    And dockingstations for (corporate line) laptops rule .
    Just don’t get that not more poeple use dockstations. they are dead cheap second hand and often fit newest series.
  18. SteveHaD says:
    I have so many old laptops and wish there was some easy way to just take the screen from each one and hook it up via dvi/vga/whatever. Please someone invent something that can handle every LCD panel out there without any effort on my part!
  19. joe says:
    xcfe is garbage. That is all.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 93,533 other followers
