Turning a tiny router into a webradio
tplink
While the hacking zeitgeist is focused nearly entirely on all those new ARM dev boards that include the Raspberry Pi, some people out there are still doing it old school by modifying existing electronics to suit their needs. [Peter] picked up one of those very inexpensive TP-Link 703n wireless routers we’ve seen before and modified it into a standalone web radio, complete with volume and tuner knobs.
The TP-Link 703n is a wireless router smaller than a credit card available from the usual Chinese resellers for about $20. Able to run OpenWRT, this very inexpensive piece of hardware can be transformed into a device comparable to the Raspberry Pi; a complete Linux system with a few GPIO pins.
[Peter] took his 703n router and added an ATtiny85 connected to two pots and the internal UART. This, along with a script to read the values from the pots, tells the router what station to tune into and what volume to play it. The audio is handled by a USB soundcard with an internal speaker, making [Peter]‘s build one of the smallest purpose-built Internet radios we’ve seen.
You can see [Peter]‘s radio in action after the break.
Comments
  1. H3ll0_w0rld says:
    Link appears to be broken.
  2. Adam says:
    I can see a black rectangle with some video controls, but no moving pictures are forthcoming.
  3. Heres the correct video link. http://www.youtube.com/watch?v=Z7XYYqrOnzI
  4. Tim says:
    @Adam here you go
  5. I believe it’s this video so I’ll leave you the link here while the embedded is still off, for your convenience. =)
  6. cde says:
    Video link: http://www.youtube.com/watch?v=Z7XYYqrOnzI
    Site has been h.a.d’ed though.
  7. muriani says:
    That’s pretty freaking slick.
    Not even using mpd, just wget piped to madplay.
    Some station management would be nice, but I think that could be easily added via a web interface.
    I wonder how well something like this would handle squeezeslave.
  8. Stefan says:
    I made a similar project a year ago, but I was using a X11 remote to control volume and radio station. Also, I build my own USB soundcard with PCM2900 and amplifier TPA1517NE.
  9. Tom the Brat says:
    Those are really cute. Don’t think I’d bother making a radio out of it. Wonder what other shenanigans I could use a little linux computer for.
    • muriani says:
      As seen earlier here, you can play games on one with ScummVM :P
      If you want something with a little more support (and slightly less hardwarehacking), the Raspberry Pi is probably a better choice.
      Personally, I like to use discarded Wyse thin-clients. Snagged a 1.6Ghz Sempron-based one for $25, “broken”. It fixed right up when I put a hard drive in it :)
      I use a Wyse J400 with a secondary NIC as a router, and it’s *fantastic*. The on-die crypto accel Via put in their CPU makes VPN a breeze.
  10. veeectorm says:
    Guys, keen in mind that not all releases of this router are fully compatible with openwrt. The latest v1.7 is not compatible as of now(ethernet port becomes unusable after getting the firmware in). Make sure you get something prior to 1.7 if you intend to buy one.
  11. ZoomZoomLuke says:
    I have used this device to run as airplay speakers using a T-Class AMP and USB soundcard.
    Unfortunately I don’t have any build logs. I also set up a web server for a roomba…
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,295 other followers
