The team at Evil Mad Scientist Laboratories needed a footstool. Obviously not content with buying one, they came across the idea of building a 555 footstool.
After finding some dimension drawings of the 555 timer IC, the team scaled everything up 30 times. While a normal DIP-8 555 is around 0.4 inches long, the footstool is over a foot long and eight inches high. The stool was cut on a CNC mill out of 1/2″ plywood, glued together, and finally panted with the correct date code and the logo of Evil Mad Scientist Labs. The finished product is amazing. We’ve been looking for a nice table, and the idea of an 8 foot long wooden 64-pin Motorola 68000 is pretty appealing.
While there’s no electronics in the footstool, it’s not hard to imagine fabricating some aluminum pins and a hollow body so a huge, functional 555 could be built. It would be possible to use discreet components following the block diagram of the 555 to build a huge Atari Punk Console; the gigantic capacitors are fairly easy to build in any event.
Subscribe for weekly videos
Ha, I love it!
Regarding a scaled up *functional* version. The original 555′s output driver can source/sink 200ma. When it switches, both source and sink transistors are momentarily active; resulting in a 200ma shoot-through.
So when Brian suggested scaled-up electronics, I couldn’t help but imagine the incredibly nasty spikes it would cause if the output current were also scaled up proportionately. :)
Djeez, why can’t I think of cool things like this. :p Looks great!
Great job and very well done! :)
Where would YOUR legs go if you scaled up a 64 pin motorola 68000?
Nice though, i could see a whole range of furniture based on this concept.
How about capacitor coffee tables?
Well…I think I have found my next project =)
@Grovenstien this is HaD, it would have to be Arduino coffee tables… LOL
make it switch a 10a 555 would work nicly
what about a gigantic cdrom for a flat screen TV, push a button and the rom oppens showing your TV
I’d be more impressed if it was functional, but with 30x the capacity of the original chip. ;)
You could furnish a super geek living room with this concept. Resistor couch pillows, Xtall coffee tables or bars (tall ones) come to mind.
That is awesome!! I also though making it functional would be fun too- and entertainingly educational. Embed a real 555 inside it, and lead out to the feet…
@pahosler to true! Giant TRI colour LED floor lamp!
pant/paint
foot stool, why does stepping into dog droppings come to my mind?
“what about a gigantic cdrom for a flat screen TV, push a button and the rom oppens showing your TV”
Better yet, make it look like a Nokia screen.
Loving it.. I know now why they have “mad” in their name…
Where is a good source of small mercury arc rectifiers? I would love to make a couple of them into a wall or soemthing.
Next on HaD, breadboard living room floors… Very cool
WANT!
OH MY GAWD, I SO DESPERATELY WANT ONE, PLEASE SHIP ME ONE RIGHT NOW!!!!!
An ideal consolation prize in the “Artistic” category of the 555 Design Contest. :p
If you want to add a working 555 circuit inside it, how about making it even more retro by making a 555 circuit out of tubes? It’s the right size to hold the tube components….
The next step is so obvious, octobot!
Wikipedia says that there are more than a billion 555′s manufactured every year (and I have no reason to doubt it), that’s such a staggering number when you think about it.
One word of criticism on this project though, I don’t think the thickness of the legs are to scale at all, but it’s not a big distraction and would require steel legs to be correct and maintain stability and somehow it looks OK as it is.
I’m pretty sure the lead inductance would go through the roof if you tried to build an actual functional IC at that size.
But since it’s just for fun, I suppose it doesn’t matter that much.
“It would be possible to use discreet components following”
The world you’re looking for is _discrete_
Talk about hoisted by my own petard
Yah, typical grammar Nazi fail. It’s a web forum post so a minor typo is ok.
Lack of periods at the end of sentences are grounds for a flogging though
That is so cool!
I occurred to me that if you made it hollow with a slot at the front, you could use it as a mailbox. Your neighbours may think it odd, but whatever.
Omg that carpet is just perfect to print/paint a pcb over it
That thing looks like it’s way heavier than it needs to be. An electron tube version of a 555 timer inside wouldn’t be a bad idea for Winter comes around, and a space heater for the room is desired. I’d definitely would buy a cutting pattern for this if they would make one available. I’d hollow it out and build a poor man’s version of the Eden Pure room heater inside.
