LCD backpack: from Arduino board to homemade pcb
[Kaushlesh Chandel] prototyped a few projects on his Arduino that use an HD44780 Character LCD. Wanting to keep these projects in one piece, but not sacrifice his Arduino board, so he etched his own LCD backpack that is Arduino compatible. If you’ve never made it past the Arduino board to build a module that only uses the parts you need for a project, this is a great source of inspiration for you to give it a try.
The design that [Kaushlesh] drew up is quite simple. It connects directly to the single in-line header of the character LCD. It looks like he’s using the 4-bit mode for addressing that display, which leaves you with quite a few pins (both digital and analog) to work with in the future. The important components rolled into his design are the chip itself, an ATmega8/168/328, the crystal to make sure it is running at the correct speed for Arduino timing, and a trimpot for adjusting the contrast on the display. The final feature you’ll want to be sure to include in your own design is a pin header for programming the chip via an FTDI cable.
Never etched your own PCB before? Give our PCB fab tutorial a try.
Comments
  1. Ren says:
    Maybe there is nothing new here, but I like the presentation and the toner transfer link, plus the idea that he left the remaining data lines available for a header.
  2. Per Jensen says:
    A fellow hacker [Thomas Flummer] at my local Hackerspace [Labitat] did a similar thing for a SMD soldering workshop, it’s a nice board too, building on the same ideas, extra I/O brought out too. http://www.hackmeister.dk/lcd-io-backpack/
  3. CWToyota says:
    I see the pot on that board (LCD contrast level) and I recognize the desire to keep pins open for other functions.
    In my U/I projects I’ve been using one PWM pin to supply the contrast. The datasheet for the LCDs has 44780 pin 3 drawing way less than the 40ma current/pin allowed on the AVR.
    If you want to keep the pin open, put a two way (three pin) jumper or DIP switch that allows you to choose where you draw your contrast from.
    If you used pin 3 to pin 3, the code would be:
    pinMode(3,OUTPUT);
    analogWrite(3, 60);
    On my MTC-16205D, PWM signal value of about 50 to 70 gives me ideal contrast with a 5V VCC. This is about .7 to .9 volts at the contrast pin.
  4. Jeremiah says:
    +1 On the PWM for contrast and backlight. It reduces your part count and makes it so you can adjust it on screen at anytime for different LCD’s. Of course you will want a small PNP transistor for the backlight.
    I do the same thing with our I2C to LCD module.
    http://www.oscsys.com/BrewTroller-I2C-LCD-Controller.html
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,670 other followers
