Here’s the situation: a kilogram of 3D printer filament costs about $50. A kilogram of plastic pellets costs less than a tenth of that. Does anyone have a solution to this problem?
For years now, the general consensus was making your own 3D printer filament at home was nigh impossible, dealing with temperatures, pressures, and tolerances that home-built machines simply can’t handle. [Bradley] sent in a filament extruder he made because he was disturbed at this current mindset that desktop filament factories have huge technical issues that have yet to be overcome.
[Bradley]‘s extruder is based on the Lyman Filament Extruder, a machine that has successfully demonstrated taking plastic pellets, forming them into a filament, and having this filament used in the production of 3D printed parts. [Bradley]‘s improvements include a variable-speed motor, a larger hot end, and an automatic timing system to produce set quantities of printer filament.
Of course, since Inventables threw $40,000 at the problem of creating filament at home there were bound to be more than a few successful designs making their way out into the public. When we last covered the developments of home filament manufacturing, the Filabot seemed to be in the lead. Now with [Bradley] (and [Lyman])’s machines turning out usable filament, it’s only a matter of time before the 40 grand prize is snatched.
Subscribe for weekly videos
So, is it just price gouging by the mfgr’s at this point?
Not really – it’s more to do with economies of scale. There are large startup costs with doing a run on an industrial extruder, so you really have to make a lot of filament in a single go before the cost-per-length starts coming down.
Since the 3d printer market is still pretty small, few people were going to take the risk of a huge, expensive run just to be left with a large quantity of filament that they can’t sell.
The economics of mass production meets the uninformed expectations of consumers.
Not loving that unguarded roller chain and sprocket. That’s a problem.
Surely, someone able to make this could never come up with a guard for a chain.
I’m sure they’ll print one up as soon as they get enough filament.
Or as it was often mentioned on The New Yankee Workshop…
Some safety guards were removed to better illustrate the procedures.
Right – because any photo posted on this site should have all the working details obscured by protective covers. Just in case the photographer decided to reach a free hand into the mechanism while composing the photo.
Clearly you did not grow up around non-modern farm machinery. :-)
Stupid question — weedwhacker string? Would that stuff work?
It’s been mentioned before on HaD; WWS (weedwhackerstring) is hydroscopic i.e. absorbs water from the air. When used in a 3D printer, the water turns to steam and forms bubbles in the product.
Thanks for the education!
I thought I also read that WWS is often “contaminated” with fiberglass, intended to strengthen it for it’s primary purpose but undesirable in 3d printing.
It has been done.
Filament is only $50 if you don’t shop around.
I buy ABS for $14 kg and PLA for $15.
Even with postage to Australia I’m paying $25/kg.
repraper.com
I’m still waiting for my filabot but I doubt I’ll bother making filament I can buy cheap.
This machines will be great for trying blends we can’t buy.
mind sharing your source of plastic? those seem like rather advantageous prices.
Always good to see someone doing what everyone else thought was impossible.
If weedwhacker string were PLA or ABS it would be a ‘maybe’ but even then it probably doesn’t have the tolerances needed. I think most weedwhacker string is nylon. This questions gets asked a lot. ;)
why would you need precise tolerances? its melted in the extruder anyway
Volume in = volume out. If the feed stock’s dimensions aren’t precise then the volume of extrudate leaving the hot end varies per mm of feed stock fed into the system.
The printer feeds filament in linearly, assuming that the filament has a constant volume per unit length. If the actual diameter varies, then the print will be inconsistent.
(It might have blobs hanging off where too much plastic was extruded, or voids where the filament was thinner than expected.)
Of course, if a printer could measure input volumetrically, uneven filament would be fine.
weedeater string dosn’t work(not the good stuff anyhow) . The filament used for 3d printers was origionally designed for plastic welders, which iirc, also take a cheaper, triangular filament.
I have printed with weed eater string alot and it isn’t difficult.
http://reprap.org/wiki/Nylon
It’s probably a stupid question, but why can’t 3d printers just use pellets instead of filament? I’m assuming the plastic they use never gets very flowable and the pellets would result in air gaps…or something.
The setup that turns the pellets into a steady stream for the 3D printer’s “head” is rather bulky, as you can see. So you don’t really want to mount it on a head that moves around the place (which is the leading mechanism). So now you have a pellet melter that feeds a stream of plastic to a mobile head a bit further. The larger that distance (determined by how far the head goes) the more difficult it gets to maintain a flow of heated plastic, it’ll cool. So you have the choice:
1. keep the plastic molten over a long-ish distance without a re-heater at the head. This is very cumbersome.
2. let the plastic cool and reheat it at the head.
To sum up: Having the plastic fed from pellets limits the distance the head can move and makes for a more complex setup.
You are correct, about the head moving, but can the head be stationary and the platform moves? I think it then solves the concern you raised.
@Rupin’s reply.
Sure it can have a mobile platform. But the problem is then translated in other issues such as how big will the total footprint be. And you’ll need to scale up your steppers.
As another person replied, it has been done. But in the end you end up juggling trade-offs and at the moment the pre-made wire sits in a sweet spot.
I should have thought of that. I guess I was underestimating how fast the plastic cools and how far from the head you could move the molten plastic.
They can. And they did.
http://hackaday.com/2012/09/24/turning-a-shipping-container-into-a-3d-printer/
The filabot people did it. I’m assuming the intermediate step is more economic in the end. You don’t want your print head heaving around a hopper full of plastic pellets and all the machinery to melt/compact them in a smaller printer.
On the filabot website, and more interesting to me, is the concept of using recyclable plastics instead of pellets. Just chop up Jr’s old toys and make new ones!
I used to work in a plastic pipe factory and they had a vacuum pump degassing the plastic where the plastic pellets first started to melt in the extruder….this was for PVC so I don’t know if it applies to this or not…thought it might be useful infomation …
I just leave this videos here and you folks decide what to make of them, ok? :)
Very cool, I enjoy the competition, but what do you mean “finally”? A month ago when you guys covered my extruder (over at projectspaghettidinner.wordpress.com or osprintingllc.com) we were making HDPE filament and weve been refining our tolerences (and adding more torque!) since then! I wouldnt call it “finally” I would call it “as well”. That said this is a sweet design, damn I love the 3D printing world
That price point is still tough to hit. I’ve said it before and I’ll say it again – it takes a lot of energy to extrude plastic and the more energy a machine consumes, the more expensive it’s going to be. The parts have to endure higher forces and temperatures and have some degree of precision.
The fact that there’s a $40k bounty tells me these guys already did the market research and if they can produce these machines in quantity for $250 each, they stand to make considerably more than $40,000. My advice to anyone who hits this price point – keep it to yourself and go into manufacturing. You’ll earn more than $40k.
The bounty could also be there to encourage the 3d printing industry without contributing hugely to landfills.
Its not all about money.
This is an important step in the right direction.
I can see a time when you have a bunch of hoppers of different colored pellets, all ready to be fed just-in-time into the production.
What I am really wanting is one that you can just drop pet bottles into that will shred them then turn them into filament.
I have done a little molding using pet before and the temperature has to be pretty specific and cooling has to be slowed down a bit but if you could build a machine to make filament out of it you pretty much have free filament.
noone believed me when i said it may one day be possible,… to make 3D printer filament at home
looks like mr crazy is sane again :)
next step? recycle already-printed parts back into filament, possible? crazy? my last idea of the “future” was crazy(making filament), so maybe this one is possible too!(recycling) :)
earth cleanup day wont be just to cleanup anymore!
it will be to restock our bulk plastic pile!
Hello,
Not crazy at all. If you can make new filament from pellets you can make it from already used ABS. Just grind it up and put it where the pellets go.
The quality of the ABS degrades if you keep heating it up, but I think it will do a few cycles if strength is not that important.
Not crazy at all. Already happening http://www.kickstarter.com/projects/rocknail/filabot-plastic-filament-maker
Don’t throw away your plastics (I’m not!). Save them for when this machine comes out and you’ll have (almost) free filament :D
What about using a dual core wire
i.e. polycaprolactone/ABS in order
to mix it at the printhead?
Best of both worlds, essentially
a plastic “epoxy” that once
hardened becomes stronger than
both on their own.
So, uh… I want one? I want it? I need it? Where can I get it? GIVE IT TO ME!!!
