robosapien pocket pc
posted Nov 12th 2004 2:59am by Phillip Torronefiled under: handhelds hacks, robots hacks
you might have a pocket pc, or can pick one up for under $100 on ebay, with that, along with a robosapien (usually under $100) you’ve got yourself a good hack project. the api (click the read link, bottom of the page) is so the pocket to communicate via ir to the robosapien. should be a lot of fun.
I have wanted to do this hack, but what holds me back is the balance issue. If they didn’t have to cut off most of the arms to make the robot walk right, this would be an awesome hack…
Posted at 10:20 am on Nov 12th, 2004 by Brendan
