Robosapien Pocket Pc
robo pocket pc
you might have a pocket pc, or can pick one up for under $100 on ebay, with that, along with a robosapien (usually under $100) you’ve got yourself a good hack project. the api (click the read link, bottom of the page) is so the pocket to communicate via ir to the robosapien. should be a lot of fun.
7 thoughts on “Robosapien Pocket Pc
  1. I have wanted to do this hack, but what holds me back is the balance issue. If they didn’t have to cut off most of the arms to make the robot walk right, this would be an awesome hack…
  2. Now, that called hack! Finally!!!
    You can design the body form and take the motor part into another part.. then use the remote control from the computer transfer to command whatever you wanted to have the bot do… It can create a pattern step by step in just one command. for example, having the bot to dance and sing “Jiggle Bell Jiggle Bell Jiggle all the way!” Lol…
    Keep on a good tech and HACK!
    deaf
  3. Now, that called hack! Finally!!!
    deaf
  4. I have an hp2215 pocket pc, but the touch screen stopped working. Is there any way to attach a mouse to the pocket pc? Its stuck on the start up where you have to touch the X’s to calibrate it.
    Any help would be greatly appreciated!
  5. defiantly a good hack, however people not willing to buy a Pocket PC, PDA could use other measures… I am a robosapien hacker, and recomend you check out my website on other hacks of controlling Robosapien.
    I added a IR/RF/IR Extender so i could control from any room with either his Controller/ USB/uirt Device or my Pocket PC
    this mod i did not have to remove his arms since the weight was minor, I also too kthe pre cautions of buying a DC/DC converter so i could use the power on the robot to actually power this new modded device on him (saving alot more space) make his balance 95% originally out of the box
    http://evosapien.com/robosapien-hack/knitsu/
Leave a Reply to deafCancel reply
