LED push buttons
led-button
[pros] has come up with a very elegant way of making lighted buttons (translated). Using a bunch of small push buttons harvested from old CD players, he rigged this unique way of mounting LEDs. Each LED has two buttons under it. They are wired in parallel, so if either of them is pushed, the button works. The LED isn’t actually soldered where it passes through the board. The anode and cathode are bent around and soldered to allow the LED a little bit of travel.¬† There’s a good picture of how he did this on the site. The rest of the details might be hard to decipher though, it looks to be in dutch.
[thanks Tom]
39 thoughts on “LED push buttons
  1. Actually, it is dutch…
    They are commenting on the original topic, but due to the mistakes in writing and using typical dutch words it will be hard to understand.
    small list of dutch translations:
    Zoja = if so
    Mooizo = Beautiful
    brouwseltje = homebrew
    toetsjes = buttons
    ledhouder = ledholder
    zorden(typo)/zorgen = making sure
    schakelaar = switch
    Hope that will help you a lot :)
  2. @rasz, I wouldn’t go as far as calling it retarded.
    Sure the wires on the LED won’t last 500,000 presses like the buttons, but for a hobby project it should work very well.
  3. rasz: I can only assume you don’t have a degree in mechanical engineering, so I won’t blame you for a little ignorance.
    LED legs are usually made (mostly) of iron, and iron is one of the materials that has a so-called “fatigue limit”, unlike, for example, aluminium.
    If you stay below this stress level, the material will never fail due to metal fatigue. This is called the infinite life concept.
    Now I don’t feel like calculating the stresses in the legs of the LEDs, but with a very small travel (say, 2mm) and the length and shape of the legs in this example, I think they are well below the fatigue limit.
    The only thing I would worry about, are the brittle solder joints.
  4. IMHO, after looking at the picture, those LED’s should hold up nicely with the little amount of movement that they will be traveling. They have enough room to move and not have any stress, although i would make sure that the ends are soldered down well enough so that the solder point doesn’t break off if it is a cold solder
  5. Looking at those initially I thought that they were being used like a two-way momentary rocket switch, so pushing the LED up a tad would push one switch, and down, the other…
    Evidently not, but I’m sure as hell going to try doing that!
  6. I’m sure you could figure out a way to connect the LED leads to wires to the solder joints. I think it would be a bit more work getting them to stay in the enclosure, though.
  7. As a fellow ME, I can soundly agree with what Sparky said above. However, for you nay-sayers, you could easily modify this by making a sharper bend in the led leads immediately upon it passing through the board, thus preventing the led from moving far away from the buttons. Then, instead of using the remaining leads from the LED to connect to the solder point, you simply use a small length of thin wire. This setup would still function properly with no fear of stress on the solder point, although the LED might jiggle around more than you want.
  8. hey guys,
    I really love that idea but when you thing about it, it does not make sense.
    Has a user, would you think of pressing an LED?
    The first thing you will think is ” There is not emboss button on the panel, I guest I need to press something else…”
    Second, you have your finger over the LED, you won’t even see it light up! :P
    Ultra bright LED might and will light up the tip of your finger.
    I will try it out.
  9. I can’t believe all the hate on a sweet hack!?!
    Anyway, as was mentioned, just add some flexible wire, it isn’t rocket science.
    I was kind of hoping it was a lighted mini toggle with up and down separate.
    My addition would be to glue/epoxy the LED to the button so that you can easily add the flexible wires.
    Or better yet, make a hole in the panel large enough to move the LED, but small enough that the LED base can’t make it through. LED restraint problem solved.
  10. The original poster, as translated from their language even mentioned the possibility of using wires instead.
    They also suggested possibly using the LED as an indicator rather than flashing with the button push.
    Say, have it latch on or off, depending on the state of the function the button controls?
  11. Some of the translated sentences are really hilarious. There is clearly space for improvement of the translation software.
    Disadvantage: low arch variants are ugly, and pretty costly.
    >Disadvantage: cheap variants are very ugly and nice ones are expensive.
    You must be a complete fool for something to remember!
    >You must be nuts to come up with such a thing!
    toetsjes pressure
    >pushbuttons
    Does there PROF. uit! off
    >looks very professional
    and legs with transparent varnish
    >spraypainted with transparent varnish
    Also out for a little less convenient when I dilettante
    >can even be done by a less experienced do-it-your-selfer that I am
    the best long-lasting I think
    >it can last for a long time, I think
    would be a pity if this topic depth collapses
    >it would be a pity if this topic fades away (or: will get burried)
    just a nice clean gatboren (= gat boren)
    >just drilling a clean hole
    especially for the genes that are not so handy with syringes
    >especially for those that are not so handy with (paint)spraying
    and you also have generous square holes drilling
    >and you don’t have to drill square holes
    (yes, this last one is exactly the opposite…)
  12. Funny how people are so alarmist about metal fatigue then as a solution suggest wires, and what are wires? Thin strands of.. -that’s right- metal.
    Incidentally the patent office must have thousands of ways to connect those LED, which nicely gives me an excuse to share this interesting yet deceivingly simple link:
    http://www.google.com/patents
    Be careful though, it’s a link that can really engross some people and before you know it an hour has passed.
    Oh and of course there are ready-made buttons with LED, so this projects is designed to do it on the cheap for people on a low budget, and thinking up expensive fixes is defeating the purpose.
  13. there has been extensive ‘research’ on this and other methods over at midibox.org, with a variation of this method coming in over two years ago.
    If I remember right, the led leads were bent out, and the led base was epoxied to the button cap, making one unit. wires connected the leads to the pcb. on a midibox, the dout is usually NOT built onto the interface panel, and all of those leds have to be individually wired to the dout board anyway, so fatigue is not much of an issue.
    The button caps were taller, such that there was room to cut a notch on top to let the leads out of the sides.
    anyway, if you are in need of button making ideas, there is several over there.. check it out.
  14. @ Wwhat:
    I did suggest finely stranded wire. It is wrapped internally, thus reducing the amount of bending any one strand endures.
    Also since the wire is stranded a fatigue forming in one strand doesn’t travel to the next strand.
    Also there are special wires designed for flexibility.
  15. @nubie
    I realise that, but I just think the feeling the pins will break in the configuration the guy uses is a bit panicky, and just as wire although it’s metal is pretty bend-proof so I expect is the setup with loops combined with the short traveldistance, but I guess only trial and error can tell, and it’s dependant, how many hundred times you can press it, on the material of the pins of the LED, which I don’t think are always the exact same composition amongst various manufacturers, at least that is my impression from the LED I’ve seen, sometimes the leads seem slightly different in composition to me, but I might be imagining things.
  16. I think the LEDs will survive about a gazillion presses. The displacement is about a mm, or less (depends on how far you have to press the underlying buttons). This millimeter is spread over 3 cm of LED legs. I doubt it will ever break.
    Nonetheless, the physics behind metal fatigue are interesting, but that isn’t what this hack is about.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
