Repairing your TV EDID
[Andreas] found that his home theater PC would not boot one day. Oddly, if he disconnected his HDMI cable from his TV, it would boot fine.  While most of us would have dug into the PC, he realized that it was a signal from the TV that was incorrect.  Luckily, LG had included a full schematic with the TV.  What he was able to figure out, using a home made snooper was that the EDID eeproms had somehow become corrupted. Not to worry, [Andreas] slapped together a full blown I2C interface and prepared to reprogram them with the correct data.  He noticed, however, that the eeproms were write protected.  On a whim, he decided to write to them any way and found that it was successful. He has some theories as to why they were writable, but says that he doesn’t want to pull the TV back apart to confirm.
[thanks evlapix]
Comments
  1. none says:
    first link is dead
  2. Whoever says:
    A modern, consumer TV that includes schematics??!!!
    Color me astonished.
    If any company were to do this with their current models, I know I’d be replacing all my TVs with those. Even if just to show them that it’s the right thing.
  3. Whoever says:
    @none: I just noticed that. 5 minutes ago it was alive, but I went back to re-read something and my super-connection killed the server.
  4. Whatnot says:
    Yeah I’m with ‘Whoever’, I used to love that devices half the time came with schematics and used it with great success to mod them, but then they stopped doing that once everything went SMD, and I guess a law changed maybe? Anyway I haven’t seen a schematic included for years, but it would be damn cool if they started doing that again.
  5. Tarnic says:
    Anyone notice what HTPC case he was using before the site died?
    BTW Google cached the page if anyone is just interested in the technical aspects.
    http://74.125.93.132/search?q=cache:http://www.lonelycoder.com/blog/?p=14
  6. googfan says:
    Link is broken my good sir.
  7. ejonesss says:
    does anyone have the images to the site?
  8. ejonesss says:
    this sounds like it was a hdcp ban.
    somehow a signal got back to the folks of showtime and they decided to add your tv’s serial number to the do not display list
  9. Kyle says:
    No, if you read it, it looks like the EEPROMs were corrupted due to faulty write protection circuitry.
    I’m very surprised they included schematics on such a recent piece of equipment. Nicely done, LG!
  10. nubie says:
    Neat, I wonder if he will rebuild the EDID info?
    I think there are some apps that can build you a custom one, or you can read it from another of the same TV, possible even just one with similar specs.
    If you don’t want to write the Edid chip can you pull that pin from a cable and use that cable with the offending display?
    I know with VGA monitors you can do this (for various reasons I don’t recall at the moment.)
  11. Whatnot says:
    I wonder too if he could have simply cut the DDC wires or are they used for other things than DDC in the HDMI standard? Or are they even a requirement and won’t it work at all then?
    With VGA they had to allow it since BNC connected monitors don’t use data channels, and BNC used to be a standard for high-end use, but with HDMI they might have gone nasty and decided to make datachannels enforced.
  12. cgmark says:
    LG included a schematic ? Something very odd about that. Maybe LG has realized the access to their service centers sucks.
    He used the parallel port but you could also use the bus pirate boards and do it a lot quicker.
  13. cgmark says:
    @whatnot
    About 15 years ago I was the owner of a warranty repair center for GE. We got everything from tv to cordless phones , they paid $45 labor to repair a $20 phone , something about customer must get back the same item. Anyway, we had thick notebooks holding about 1000 pages each with schematics and service manuals to all the devices. The shelves holding the manuals took up a entire wall, there was about 25 of them . Later updated to cdrom and could pull them up on a pc.
    If something came in we didn’t have the manual for we had to pay $30 to get it from sams photofact. They still exist today online http://www.samswebsite.com/photofacts.html
    For me now the problem with devices is not the schematic it is identifying the chips themselves. They have started doing one off chip production runs where they only mark the chips with batch numbers . Sometimes you get lucky and they have the company logo of who made the chip but sometimes even that doesn’t help. Often the service manuals will show the connections to the chip and what voltages should be present but still leave out what the internals of the actual chip are.
    To make it worse companies like broadcom, oh how I hate thee, are so paranoid about their designs you can’t even get datasheets unless you get a lawyer and have wads of cash to throw at them.
  14. Wutang36chambers says:
    I one had a a repair man replace the lcd on my samsung 47″ – the guy looked like a plumber turned tv repairman, my 9 yr old daughter could have done the job (aside from the lifting). There was only about 4 wires inside the whole tv aside from the speaker connecs and the power…
    He accessed some type of manager mode using a thumb drive and some button code, I tried to get it out of him, but he wouldn’t budge.. Maybe I should have bribed him with a 12 pack or a $20?
  15. jim says:
    what i’m understanding here is that you can write malware to screw people’s TV HDMI info and botch their sets
    basically this makes for another problem that bewilders most tech people as much as grandma is bewildered by gmail. fun times!
  16. m20120 says:
    The EEPROM was not write protected. Pin 7 is the Write Control line and it is active low. Pulling it to ground allows the EEPROM to be written to. Pulling it high would write protect it.
  17. ejosh says:
    @Wutang36chambers: You can get into the service menu of many Samsung tv’s by turning off the tv and pressing Mute-1-8-2-Power.
  18. nes says:
    I don’t get why he couldn’t have done the writes over the PC’s SM bus instead of hacking up an HDMI cable. There is a Linux userspace lib for it, just as there is with the parport.
    I think he’s actually read out a page from the EDDC data rather than the EDID. That could be why the preamble doesn’t look right. There’s another register in the TVs EDID PROM to switch between pages. Maybe that got poked by something running on his PC and it just got left in that state.
  19. James says:
    I still don’t understand how an error in a *peripheral* (your TV, hooked up over HDMI) can keep the *PC* from booting. Can somebody straighten that part out for me?
  20. Andreas says:
    @nubie – It was only two bytes that was corrupted in the EEPROM. After fixing the header, the EDID checksum matched.
    @James – This is the biggest mystery of all. Perhaps it’s just a bug in the GPU BIOS. I don’t suspect these type of erros happen that often
    @nes – I didn’t know that the driver exposed the i2c bus until after I rewrote the EEPROM. However, it seems the nVidia driver does not allow write access to the EDID ROM. I did not investigate why.
  21. Stu says:
    Man, that is worrying.
    I’m thinking of replacing my dead old Packard Bell EHR2080 DVR with a home theatre PC.
    I dont want to plug a GPU into my brand new 40″ Sammy only to have it corrupt the TV’s firmware (if thats how it happened)!
    I’m into electronics and home repairs myself (Tried to repair the DVR to no avail, the PSU outputted correct voltages on all rails, problem was on the mainboard with those scary big SMD chips!) but I wouldn’t even know where to begin to fix my TV!
    And no, Samsung did NOT provide schematics.
    Great work there Andreas!
  22. nes says:
    @Andreas re. E-DDC pages, there’s a rough description on WP:
    HDMI sets have to have it, and unless I’m mistaken that’s a 256 byte EEPROM in your set, meaning you could have one extra page of EDDC. E-DDC ROMs are meant to reset to reading the first page if anything goes wrong so that older equipment (e.g. your BIOS maybe) can still recognize the display. However some I2C EEPROMs don’t implement this and will maintain their state even if power cycled.
    Just saying that /could/ be what had happened here.
  23. nes says:
  24. squidarthur says:
    The best hack posts never have flames or trolls in their comments, just a bunch of people exchanging good information about a great hack.s
  25. joao says:
    My toshiba panel came with all the schematics.
  26. cgmark says:
    Don’t worry about a home pc corrupting eprom data on your tv. This hack is an example of how NOT to design a display. Most manufacturers are aware that the EDID data does not need to be accessed by anyone except service personnel and will block write access to the chip unless the display is in service mode.
  27. GCL says:
    Site’s back.
    Interesting concept. The site he referenced had more interesting information, and an interesting hack regarding what can be done to confuse a system running Windows from the point of view of a system running Linux.
  28. thecauseandeffect says:
    @James
    When windows 7 was still beta, I my pc was stuck in an infinite start up loop. If i switched from dvi to vga during the install, everything worked perfectly. after the fact i could use dvi again. mystery.
  29. YNH says:
    A call out for anyone who know the case he is using for the HTPC! Awesome case and i have just started looking for one.
  30. BotherSaidPooh says:
    This might be a way to insert custom resolutions into a stock monitor, I noticed this “feature” on my Samsung lappy.
    The panel actually supports 3D via alternate frame but as there is no way to output the sync signals to glasses I’d need to use the webcam LED or something creative.
    Another related hack, modify a cheap tablet to do 3-D by adding a simple LM1881 on the sync output to send the required IR pulse.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,278 other followers
