Nook color rooted: Hands on
posted Dec 12th 2010 10:44am by Caleb Kraftfiled under: android hacks
Nookdevs have released information on how to root your nook color. So naturally, I had to run out and get one. Who doesn’t want a multitouch android tablet for $250? The instructions for rooting are extremely simple. You really only need microSD card and a Linux/Windows/Mac computer to connect to. After rooting, your nook will work exactly as it did before, but you can now install android applications on it. Many applications are built for a phone that has more physical buttons, so I have run into some issues, but over all, the applications that work tend to work well.
Join me after the break for more thoughts, a video of it in action, and a few pictures.
The specs are decent, with a 1024×600 screen, 8GB internal storage with microSD expansion slot, wifi, and an 800MHz ARM A8 processor. As you can see in the last picture, the viewing angle on the screen is fantastic. The battery probably won’t last the advertised 8 hours playing games, but I haven’t had to charge it yet and it has been playing music, browsing the web, and amusing children for about 24 hours now.
Installing software is a bit of a pain. You can’t install things directly from android stores online through the device yet. Instead, you have to search the web for the .apk file to download then install it via the command line on your computer. This can be a pain because the .apk files are rarely labelled with which release they are, so I’ve gotten a few older versions of software that simply wouldn’t work even though I’ve seen them working in other youtube videos. So far I’ve gotten decent use out of the Dolphin browser, Google Maps, Pandora, and Angry birds. I wouldn’t be surprised to see torrents popping up with bunches of tested applications for nook. hint. hint.
Removing applications can be a pain too. The theory is easy, you open the console and view what files are installed, then issue a simple command to remove the one you want. However, they don’t necessarily install with an obvious file name. For example, I installed google voice search. Realizing I don’t have a microphone, I went to remove it. However, there are several files labelled google and none have the word voice. How do I know which one it is? A quick google search would probably find me the answer, but I can’t wait till I can just drag the icon to the trash can.
Over all, I can’t wait to see how much better this gets. If I could install software from the android stores I find online, have flash, and remove applications easier, I’d be very happy.
I’ve been tempted to run out and get one as soon as I heard about the first success. I’m even more tempted now. Time to do a little debian/ubuntu research!
