Satellite Monitoring For Bridge Maintenance
In our developed civilizations, there are a great many bridges all serving as important transport links in their local communities. As solid and unchanging as these structures may appear, they require regular maintenance over the decades to stop them falling apart with catastrophic consequences.
Only, to know what to maintain, you have to monitor the bridge’s condition, and check how it’s sitting or shifting over time. Unfortunately, this can be an incredibly time-consuming process when there are thousands upon thousands of bridges to keep an eye on. But as it turns out, in this regard, satellites can help.
Eye From Above
While it’s easy to think of bridges and buildings and other built structures as stable, solid, objects, it’s simply not the case. You only need to look at houses with giant cracks in the brickwork in neighbourhoods with subsidence to realise that even the things we build move over time. When it comes to bridges, they’re moving all the time—sagging a little under the weight of traffic, swaying with a heavy breeze, or shifting as ground conditions change with the seasons. This is all perfectly normal, and something that engineers take into account during the design process. It’s why bridges have allowances for this, with expansion joints and cable stays and so forth.
The real problem is determining when a bridge has moved in a way it’s not supposed to. Maybe a foundation is sinking faster than expected in a soft spot in the ground, or excess loading has pushed a support past its limits to shift it out of place. These sorts of issues can put a bridge at risk, potentially leading to expensive damage or catastrophic failure. Unfortunately, these problems can be difficult to detect. The traditional way to find them is with regular inspections, sending out survey crews to take manual measurements to figure out if everything is still sitting as it should. It’s a labour-intensive process, and one that doesn’t scale well—it’s a herculean effort for many transport authorities to keep up with these sort of inspections across a full network of bridges and spans that are all slowly aging in place.
BRIGITAL is a project that aims to solve this problem. It’s a piece of software devleoepd by the National Research Council of Canada and the Satellite Applications Catapult. The concept is straightforward—BRIGITAL collates data from a variety of sources, including satellites, visual inspections, and sensors on the ground, and then turns it into a visualization showing displacements on the bridge with millimeter-scale accuracy.
A screenshot from the BRIGITAL software, showing hotspots of higher displacement. note the units—mm/C, referring to the displacement caused by thermal expansion or contraction. Credit: Catapult/National Research Council, Canada
The real game changer of the project is the use of satellites, specifically those with interferometric synthetic aperture radar, or InSAR. Satellites used for this work combine radar returns from several small antennas to create a high resolution radar scan up t0 250 mm in resolution. Unlike optical imaging satellites, InSAR can operate through cloud cover and other weather conditions, enabling data to be collected on a regular basis with far less interruptions. This enables bridge measurements to be made regularly without requiring a team of human surveyors to go down to the site and do it all by hand. Measurements are taken with an eye to determining both linear displacements, as well as displacements due to thermal expansion and contraction, which can be very important as a bridge can experience huge temperature variations over the four seasons of a year.
BRIGITAL was used to study the Jacques Cartier bridge in Montreal, with displacements observed landing within expected limits. Credit: Antony-22, CC BY-SA 4.0
As a result, BRIGITAL and the visualizations it creates are able to give bridge engineers a quick look at exactly what a bridge is doing and how it is faring over time. Any hot spots where displacements are excessively high or outside of expected behavior can quickly be detected and focused on for further investigation. A particular early case study investigated the historic Victoria Bridge, in which satellite data was compared with analytical and numerical predictions of the bridge’s displacement over time. Another was the Jacques-Cartier Bridge in Montreal, where BRIGITAL was able to show that the bridge was behaving as expected, with expansion and contraction observed in the satellite data matching modelled predictions by the research team based on ambient temperatures in the area.
The great thing is that SAR-capable satellites and the resultant datasets are not exactly hard to come by in this day and age. There are many constellations that could be employed for this work and used to monitor bridges all over the world. It’s really only a matter of taking the data and using the right tools to analyse it and monitor changes over time. In many cases, there would be no need to invest in expensive new infrastructure or satellite constellations—the birds are already up there, and the data already exists. It just needs to be put to good use.
Going forward, tools like this could prove a useful early warning measure for bridge engineers and transport authorities. Automated measurements could be run regularly from satellite data, with systems like BRIGITAL sounding the alarm when excess displacements are detected—often a clear sign that something is wrong on the bridge. Given the huge costs and often tragic outcomes of a major bridge collapse, any sort of forewarning that could prevent disaster is worth its weight in gold—much like the satellites that make such monitoring possible!
