Teardown: Audiovox MVX-450
The modern smartphone is a wonder of engineering — perhaps the ultimate demonstration of not only the incredible economies of scale, but of miniaturization. A computing device capable of going head-to-head with a desktop machine from a few years ago, small enough that it can fit in your pocket, and so cheap to manufacture that low-end entries are effectively disposable.
But for hackers like us, those traits come at a considerable cost, as the modern smartphone is increasingly an unserviceable black box. Even in the best case, you might be able to swap out a few modular components such as the battery, screen, or camera. But actually doing board-level repairs is out of the question, as even in the unlikely event that you had the schematics and could diagnose the problem, the density of the PCB and the size of the components makes working on such a board all but impossible.
iPhone 5S Mainboard. Credit: Raimond Spekking
It wasn’t always this way. There was a period, albeit relatively brief in the grand scheme of things, where you could open up a phone and find PCBs that could conceivably be serviced by a hobbyist. We’re not just talking about those hulking late-80s units that came in their own carrying bags, either.
This Audiovox MVX-450 from 1995 is a perfect example. While it admittedly doesn’t pack in a fraction of the capability present in a modern smartphone, and in truth is pretty simplistic even when compared to the “dumb phones” of the early 2000s, it’s a perfectly capable mobile telephone. Despite being considerably thicker, it probably isn’t much larger than the phones most of us carry around today, either. Yet crack it open and you’ll find a remarkably approachable design, complete with through-hole components and even a few hand-soldered bodge wires.
User Serviceable Parts Are Inside
To be clear, it’s not that the internals of the MVX-450 are simplistic exactly. Sure, it’s a far less complex design than that of a modern flagship phone, but there’s still quite a bit going on in there compared to your average hobbyist project. It’s also true that the PCB itself is still fairly dense, and some of the components are small enough that replacing them would take a steady hand and no small amount of experience.
But even so, upon opening the phone and looking at the PCB, one is immediately struck with just how familiar it all looks inside. From a modern perspective, the last thing you’d expect to see in a phone are SOIC8 ICs, SOT-89 transistors, and 0805 passives. It’s not an exaggeration to say that there are children’s toys on the shelf this holiday season with more intimidating board layouts than this.
That being said, just because the MVX-450 uses parts that can be hand-soldered doesn’t necessarily mean fixing it would be a walk in the park. Ignoring the fact that there’s probably nobody in the world who’s actually concerned with trying to repair one of these things in 2026, the Toshiba chips the phone was designed around aren’t exactly jellybean components.
A Phone in Two Parts
The keen-eyed reader may have already noticed that the main PCB of the MVX-450 doesn’t actually have any of the radio components on it. This may seem odd, but again, that’s only because of our modern conceptions of how a cellphone should be constructed.
Anyone who’s taken apart a pager of this era will probably recognize the design philosophy at work here. The main PCB of the MVX-450 is responsible for the user interface, while the radio hardware is pushed off onto a separate daughterboard. This approach simplified the design of the two individual boards, and made it possible to produce carrier-specific variants of the phone by simply swapping out the radio PCB during final assembly.
Somewhat surprisingly, the radio PCB mounted in the back half of the phone’s case appears to be even more simplistic than the main board in the front. Here we can find THT crystals, trim pots, and even a couple bodge wires for good measure. You’d never see these little human touches inside of a modern phone — even if there was room inside for this sort of nonchalant engineering, it would have to be optimized out due to the sheer number of units being manufactured.
Form Follows Function
Some will undoubtedly look at the construction of the Audiovox MVX-450 and bemoan the design of current mobile phones. If they could build a phone like this in the 1990s, why can’t they do it today?
The answer, of course, is that they certainly could. It’s just that what most people think of as a phone today has only a passing resemblance to devices like the MVX-450, so the comparison is fundamentally flawed. The market demands ever more powerful mobile computing devices, and so that drives every aspect of their design.
Projects like the ZeroPhone and the Rotary Un-Smartphone show that it’s possible to build a modern mobile phone that’s repairable and hackable, so long as what you want is actually a phone. But the reality is that the potential market for such a device is simply too small to be attractive for any of the major manufacturers, and so they will remain the exception rather than the rule.
