[Andrey Mikhalchuk] is trying to gather a base set of lab instruments. Specifically, he’s looking for hardware that will let him quickly filter solids out of a liquid. He first started by adding a cotton disk to a plastic funnel. It does the job, but when left to gravity it’s quite slow. He needed a way to speed up the flow even when the filter is heavily clogged with particulates.
There’s already a solution to this problem. It’s a glass container called a Büchner Flask. These feature a glass tube coming out from the neck. By hooking a vacuum pump up to this tube, reduced pressure inside the flask will pull the liquid through the filter in no time. Rather than purchase the specialty item, [Andrey] altered a rubber stopper to accept both the funnel, and a glass tube. This is a cheaper version because it uses a common conical flask but it works just as well. To create the vacuum, an altered bike pump was used. Check out videos of both hacks after the break.
Subscribe for weekly videos
They better not be filtering the solids out of bong water for re-smoking, because that’s gross.
Don’t ask me how I know that…
In all seriousness, that’s using some resourcefulness to achieve the intended results.
Very cool.
As a chemist, one of the best ways to make a cheap vaccum is to use running water, using Bernoulli’s principle : add a T to your tap, and run water through the “top” part of the T. A vaccum is going to form at the base, so connect your tube to it. Its a cheap and effective way, although it does waste water.
There were a lot of ingenious suggestions like this in the old Scientific American projects book…
The Scientific American book of projects for the amateur scientist
And the glassware hacks aren’t even all that dated. Sadly, I see even the used copies, only 2 available, are going for USD$50 and up.
I spent many hours with that book in my high school library back in the 1970′s; it was already dated, but the ingenuity and creativity shine through. If Hackaday was a companion site to a major scientific journal, it would be that book.
(In sadder news, SciAm is today a pale shadow of what it was in the days when a book like that could be accumulated from its columns.)
Wow, does Hackaday always expand it like that when you post a URL that happens to be an Amazon book link?
Oh, and it’s awaiting moderation even though I’m a known user?
Should make an attachment for your vacuum cleaner. That will speed it up :-P
LMAO. Wow – so now you are featuring kindergarten level “hacks”. Very nice.
I am with DdD – why piss around making a lame vacuum pump when you can let your faucet do the work.
There really should be an intermediate vessel in that setup.
Looks like the job of filtering my apple cider juice from pulp just got easier.
Hard apple cider here we come!
Yeah I agree with localroger When i Was little kid The books even old ones were made so much better older tech but the material was A+++ even popularmechanics was 10 times better 1 time i found an odd shaped book my dad got at a garage sale it was as thick as a big phonebook but the pages were only half the width ( i think it was so you could take it anywhere) and it had every Macgyver hack Known to man for the time,lab,eletronic,build anything,fix almost anything… then years later my buddies brother was taking classes and was going into the FBI and instead of 70′s burnt orange it was black same shape & size but black! It had a strange title to But thats all I remember anybody else remember a book like that?
TheCreator: Great idea! However there is a problem with vacuum cleaner … when the funnel is empty it starts sucking air thru the system and can pick up a drop or two of the product.
Now the question is what are you filtering. If it’s just a dirty water the vacuum cleaner probably will be fine, just smell bad. If it’s ferric chloride (the stuff I built it for) – that’s whole different story and it’s not very long (for the vacuum cleaner).
Pump is safer. It also doesn’t need batteries so you can use it outdoors. And if it will pick up some bad stuff you can always get another one for a few bucks.
well Localroger….not sure why my amazon id better than yours but http://www.amazon.com/gp/offer-listing/B0010XX7EW/ref=dp_olp_0?ie=UTF8&redirect=true&condition=all
1. If you can spin the funnel+filter rapidly /before/ turning on the vacuum, the sediment should slide to the outside, leaving the center fairly clean, so the liquid can be pulled through faster.
2. Here’s a fun little file for you science buffs, from 1861: ftp://ftp.sac.sk/pub/sac/educult/science.zip
As a biochemist, I’ve used Buchner flasks hundreds of times with Buchner funnels. I like this homemade version, although I doubt I would ever use it in the lab :) We have, however, used very similar versions (no filter, just two tubes out the top) to create vacuum traps between the Buchner flask and the vacuum source.
I would suggest cutting off the top half of the filter he’s using, then cut and glue a cylinder in place. Fit a circular disc of plastic with holes ~2-3mm apart at the joint of the cylinder and sloped area (just like how he did it with the plastic milk cap). This will give you a decent Buchner funnel. Being flat, it keeps your product from getting too congested in one area. I would also recommend using filter paper discs cut out of coffee filters if you can’t get any decent qualitative filters. Just make sure that they’re of identical or slightly larger size to the circular disc you made earlier.
Finally, I would recommend using an aspirator on the tap for creating a vacuum. I believe [DdD] mentioned it earlier, although I was unsure as to what exactly he was talking about (aspirators rely on the Venturi effect). I would imagine that they’re cheap (plastic at least), although you can easily build one yourself with parts at the hardware store. These create great vacuum and if you’re worried about wasting water, you can always recycle it. Wash some dishes or something while it’s filtering :)
pretty good buchner funnel/flask
only problem i see is that if you were going to keep the retentate rather than the filtrate and it was critical for it to dry for 5+minutes with a regular vacuum set up, you’d get tired pumping and probably wouldn’t work as well as if you had a real vacuum
It used to be that most university labs had a resident glass blower to make up anything that couldn’t be cheaply bought. I hear they’re all disappearing.
If you need vacuum, obviously all you need to do is tie a helium balloon to a really, really long hose and let it float up to the edge of space. Thus you get vacuum on the other end of the hose…
…well, at least I’m pretty sure Wyle E. Coyote would do it that way.
(disclaimer: yes I’m aware the concept is broken in at least a dozen ways – why so serious…?)
Seems like a good variation on the Aeropress for making top coffee!
I figured he would use the burner to polish the cit of the glass tubing. I seem to recall that’s how we did it in school. Maybe I missed in the video I expect to see him remove the check in the tire pump. No doubt the scientific America book is out there on the web somewhere, and it looks like some of the material from the book can b for on a CDROM from Scientific American. The book describe as in good condition can be found used as low as $28. This http://www.noah.org/science/x-ray/stong/ is credited to the book.
Ah, memories…
Working in a “pharma-industry supplier” company, we still sell some of these systems. They are decades-old but very practical when you’re on the field and need to filter water samples for microbial charge evaluation. They don’t need electricity, can be flamed ‘sterilized’ if used in conjunction witha glass or stainless steel funnel and are very resistant to shocks. We even probably have somewhere in an old catalogue small incubators that can run from a car’s battery…
I still have in my little personnal museum a [gorgeous] stainless steel syringe from 1979 with a “T” connection at it’s end which pulls liquid at one end and blows it at the other end, removing the need for a Büchner flask.
One thing worth thinking about is that buchner flasks are (were?) made of thicker glass than plain old conical flasks. Sort of like Champagne bottles being thicker than still wine bottles.
Plainly [Andrey Mikhalchuk] isn’t going to have a problem given his bicycle pump, but would it survive a vacuum pump? I’m thinking of a salvaged pump/compressor assembly from and old fridge or freezer.
I realise that the filter would have to be seriously blocked, plus anyone doing this sort of thing should be both wearing safety gear and paying attention, but in my experience imploding glassware is much the same as exploding glassware, plus not all solvents are benign.
Just a thought.
The scientific American book can be found on rapid share. Doesn’t lend itself well for reading using the computer, but 605 pages is a lot to print. You have to rotate some of the page images to read using the computer.
http://preview.tinyurl.com/3g67uwx
or the long one
http://rs420cg.rapidshare.com/cgi-bin/rsapi.cgi?sub=download&editparentlocation=0&bin=1&fileid=73186967&filename=Amateur_scientist_1960.rar&dlauth=9195AD8D44D66A782C949C8FA65CE1C046F0563BA0EE91ABD094B1DE3C9C37342760A473D6427B615B32C280D1471E269F54526D6BA57A85E213824A0B7F27A76298CA8487D3B47E2FB5C772B13F5E8F52F9CE65D5088BC2F988BA187A48DCB3E5D3BF59DAE87C55B6E10C356548C984#!download|420l34|73186967|Amateur_scientist_1960.rar|20299
Alternatively if you have some spare fittings and an air compressor, you can create a vacuum without water, having to use a bike pump, or worry about ruining your Shop Vac.
I like the DIY aspect but, you do have to have a cost/benefit mark to go by. For instance, you can buy a buchner flask, gooch crucible and stopper for less than 20 bucks. Not really worth it IMO but, it is still neat seeing people using their brains.
Pete: Could you please send a link to a $20 set? I was looking for one before building my own but the only one I found was $70 shipped from ebay (including the pump). This setup could be done however with
- Jam jar: free
- water plastic bottle (for the funnel): free
- I found they use nice plastic tubing as a part of helium balloon holder in Party city: free
- bicycle pump: $8 (got mine from Target)
- filters are cotton disks or coffee filters (the latter is in fact better because they are lint-free) or paper towels – basically free
So the total cost of this setup is as little as $8 (for the pump). I only used Erlenmeyer flask, rubber stopper and glass tubing because I had them, all these are replaceable (I added a note about this to the building blog).
@Aundrey:
http://www.agile-fx.com/servlet/the-1933/Flask,-Filtering,-Light-Duty,/Detail
plus
http://www.novatech-usa.com/Products/Laboratory-Porcelain/PBF070
plus
http://secure.sciencecompany.com/Rubber-Gasket-or-Vacuum-Filter-Aid-P16545.aspx
would be $17.43
Looks like this place http://www.amazon.com/Filtration-70mm-Buchner-Funnel-Flask/dp/B0018RUCDY sells all three for $18.95 together.
Admittedly shipping is not free.
I am not suggesting you go out and buy these things however. I was merely stating that everybody has a point where making your own equipment is either too much work or costs too much to make it worthwhile for them. ~$20 seems like a small investment for lab equipment. Who here would spend that same $20 on a “build your own led throwie” kit? No one here I’d bet.
password for the rarfile
:)Merciatous(:
Pete: Thanks for the links! That’s $28 shipped and without the pump, still a great price, better than what I found myself.
I also agree with your point. If fact the idea I had while making the video was telling about different approaches to speed up filtration, not building the lab equipment. Hard to believe, but there are a lot of people out there who do not know about vacuum filtration :)
Thanks for good criticism!
Exactly what I need when making Almond Milk!!!!
