Arduino releases new products; help them develop ARM-based Arduino
The Arduino folks took advantage of Maker Faire New York to announce their new line of products. There’s several interesting new additions to their product line.
They’ve got a WiFi shield in the works that utilizes a module from H&D Wireless in conjunction with an AVR32 processor to take the workload off of the ATmega chip on the Arduino board. It even has room for you to run your own code on the shield’s processor.
Notable (but of less interest to us) is the 1.0 release of the IDE and the development of a new low-cost board. That hardware is intended to make USB device development easier for those already familiar with the Arduino platform.
But the big news that caught our eye is the announcement of an ARM Cortex-M3 Arduino called the Due (we already wish that had been named something different just for search term contrast to the Duemilanova). The hardware hasn’t been finalized yet, although you can see a prototype in the picture above. They want community input on the final touches, so get in there and give them a hand!
[Thanks Insapio and Tom]
Comments
  1. Mudo says:
    ARMduino would be better name…
  2. charliex says:
    Couldn’t have come at a better time. though i do wonder about the existing armduino’s like the maple etc.
  3. cknopp says:
    Here’s hoping that this will become part of the RadioShack lineup!
    Just got communication this morning that we will have a large selection of Arduinos within the next few weeks.
    If anyone is in Knoxville, stop by and see me in Turkey Creek!
  4. Beat707 says:
    Yes!! Long live the Arduino! :-)
    But honestly, we would love to see more external SRAM on those babies. :-p
  5. ScottInNH says:
    @Beat707 – All these boards come with whatever SRAM and Flash and EEPROM that the host microchip was built with.
    By keeping memory out of the board design, it helps keeps cost low.
    If you want more memory, there are a lot of instructables for building a memory board of any type. I have not built one but they all look very simple to build.
    (But it seems to me very few sketches ever need even 64K… the big memory using sketches I have seen all could have benefited from storing strings in the underutilized Flash and EEPROM.
  6. Bergo says:
    they could “fix” the pin spacing :D
  7. HHH says:
    All I know is that they better choose a better name. “Due” will only manage to confuse Google Instant
  8. svofski says:
    And don’t forget about chipKit MAX32 which is out already and has more SRAM.
  9. I’m excited for the 32u4. I’ve had one from lady ada and the whole time I’ve been like.. 2 chips=dumb. I think the underpinning of recent Arduino awesomeness have been because of LUFA. If you hadn’t a chance to play with it yet get a hold of it…
  10. lostalaska says:
    It looks like it has quite a few more pinouts to hook up to which would be a welcome addition. A little hard to tell from the picture, but does it also have more PWM pins? That would also be quite helpful for a few of my projects.
  11. Spot says:
    I really want something in DIP package. i can’t handle those tiny chips on a standalone projects…
    • ScottInNH says:
      @Spot: they solder the tiny chips on for you.
      ave you counted the pins? The cost of a DIP would be insanely cumbersome and the sales would be awful.
      I imagine DIP breakout boards exist, or will soon.
      I prefer DIP for most things also, but more and more DIP is being left behind. Economics..
    • DanJ says:
      I like the DIP packages for various one-off projects as well. Another possibility is to buy a cheap Arduino (clone) for use as a programmer and then buy a bunch of blank DIP AVR parts. You’ll have to build a little perf board that has a socket to plug the blank DIP parts into.
      You can use the Arduino to load the Arduino bootloader into the blank parts. Then you can use a FTDI cable to program your DIP Arduinos (even when plugged into your final circuit with a little forethought). Makes it possible to easily upgrade the firmware in your device.
      Or you can setup your own AVR development environment and use your Arduino just to load the final program directly.
  12. ftorama says:
    Don’t let the Teensy die ;-)
  13. rasz says:
    It is 3.3V so not compatible with current shields anyway. they should fix pinout and use it as an indicator of 5/3.3 IO voltage
  14. Gray Simpson says:
    @rasz – Great call.
  15. engineersteve says:
    I bet the bga or qfn package is cheaper. Is there a manufacturing limitation or are they scared to pitch out a bga?
  16. Threeck says:
    I just wish people wouldn’t use this to blink LED eyes on a Jack O’ Lantern.
  17. tantris says:
    if this means easy arm development-ide with a c library, wonderful!
    there are arm boards under $30 out there already. no need to go for a clone then..
  18. George Graves says:
    I’d love to see an arduino board that had an extra socket for 8 pin DIP Atmels as well….That would be great.
  19. JohnnyMax says:
    It’ll have to offer a lot more to take on the Raspberry Pi.
    I have just upgraded mine with a £1 usb Bluetooth adapter, a £4 Wifi adapter and it’s pulling ADC readings using a Arduino.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
