Last chance to enter The Hackaday Prize.
Researching cosmic rays with cloud chambers
In the late 1940s, the US Naval Research Laboratory used a few German-built V2 rockets to study cosmic rays from above Earth’s atmosphere. To do this, a nitrogen-powered cloud chamber was fitted inside the nose cone of these former missiles, sent aloft, and photographed every 25 seconds during flight. When [Markus] read about these experiments, he thought it would be an excellent way to study cosmic rays from a high altitude balloon and set about building his own Wilson cloud chamber.
Cloud chambers work by supersaturating the atmosphere with water or alcohol vapor. This creates a smoky cloud inside the chamber, allowing for the visualization of radiation inside the cloud. Usually the clouds in these chambers are made in a very cold environment using dry ice, but rapidly decreasing the air pressure in the chamber will work just as well, as [Markus] discovered.
[Markus]‘s small cloud chamber uses a CO2 cartridge to provide the pressure in the cloud chamber before dumping the CO2 out of the chamber with the help of a solenoid valve.
In the video after the break, [Markus] demonstrates his cloud chamber by illuminating the cloud with a laser pointer and introducing a few alpha particles with a sample of Americium 241. It looks very cool, and seems to be useful enough to count cosmic rays aboard a balloon or amateur rocket.
Comments
  1. ffffff says:
    Interesting use of CO2 cartridges, but due to all the turbulence I don’t see how it would be possible to see collisions and splits without a lot of luck and a high speed camera.
    Perhaps this could be combined with a peltier cooler to make the CO2 charge last longer…
  2. jordan says:
    Peltier coolers work wonders for this!
    I had a cloud chamber rig going a few months ago but I put an aluminum baseplate in the chamber that was too large for my wimpy peltiers to cool properly.
    Eventually I’ll test all the ebay TECs I ordered and rebuild the chamber because they are incredibly cool. You really do see ambient radiation.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 91,150 other followers
