Here’s the latest entry in “future robot overlord watch”. Each stick is driven by a pneumatic cylinder. The control is generated using a midi file as the source. The system is completely modular. You assign instruments to individual channels based on what you have so it should be able to play any kit. My favorite quote from the FAQ: Q: What do you use to generate the midi files? A: Google.
[thanks synth-c]
