Hackaday Links
First a request: I know some of you have had some experience hacking together Greasemonkey scripts. Jim Hanas over at Hanasiana has a quick project he needs help with. Go ask him for the details.
The Nano cases keep rolling in: Here is [Atonomie]’s leather Nano case. Use the template to get a head start on your own case.
More CSS/Javascript/Ajax fun:
CSS/Javascript chat room [wtanaka]
Custom Ajax homepage [Andrew]
[ondras]’s universal SQL & er-diagram designer
[Biggs] built a remote shutter release for his 350D out of a mouse.
Custom Slim Devices control boxes by [chrisla]
[colin]’s super cheap laptop cooler
A ton of laptop photo frames [rob]
[eitan]’s Zen Micro Altoids case
Magnetic levitation demonstrator
[Jonathan Zornow]’s guide for abusing iDVD
Cheat sheet for getting a human operator [hazar via In4mador]
The tip line
Continue reading “Hackaday Links”
GBA Variometer
vario
Variometers are used by para/hang gliders to measure their vertical climb/sink rate. This data helps pilots find and catch thermals. The software runs on a flash ROM cartridge and captures flight data. The data from up to 50 stored flights can be recalled later. The altimeter is a simple pressure transducer that plugs into the link port on the Gameboy Advance.
[thanks Sean2e]
Continue reading “GBA Variometer”
