The HD4478 is an extremely common LCD controller. The folks at Sorgonet got this particular display out of an old credit card reader. It’s easy to talk to these controllers using just a parallel port cable. With the lcdmod project you can send text strings directly to the display from the command line. Sorgonet has a lot of related LCD links if you are interested in putting a display on your next project.
[thanks h-tech]
