This is a proof of concept magnetic stripe card emulator. Adron embedded a thin strip of metal into track 2 of the magnetic stripe. The ends of that strip are wrapped with thin copper wire to create a solenoid. The solenoid is driven by a PIC microprocessor and some transistors to boost the signal. The software provided can pulse a test pattern and any additional card numbers you supply.
