[Hybrid] tipped me to the ‘CREATE USB’ interface project. In truth it’s nothing more or less than a nice, (fairly) simple project to provide hardware hackers with a handy USB interface. It’s based on the PIC 18F4550 processor. If you check out the project, you’ll note that not only do they have a nice board to put a SMD PIC onto, they provide everything you need to build a diy version using perfboard. The most expensive component is of course the $10 PIC, but if you’re on a budget, that can be mitigated with a request for samples. (don’t abuse it – I think they’ve already cut back on sample amounts due to over-use.)
Hey, don’t forget, the Design Challenge deadline is the 25th. (This wouldn’t make a bad entry with some adaptation…)
