29 thoughts on “In Bag USB Cable
  1. unfortunately this won’t work when the usb ports are a bit recessed.
    so… why the pcb? if you glue the cable end to the plug properly (hot glue or epoxy), it even withstands some serious pulling.
    the real practical part of his mod is the usb hub in the lappy bag.
  2. Come on man it’s one hack per day, it can’t be easy finding 365 “omgwow” hacks. Plus, the best kind of hacks are those simple things that make life easier.
  3. I can see the use but sorry its not much of a hack and given yesterdays headphone socket hack 2. Whats next – howto strip and twist wires for solderless hacking ?
  4. jeez, what is everyone’s problem with this?
    its a GREAT idea, i would personally kill for a usb hub i could plug in to the back of my laptop and put it in the bag as is without worrying about snapping off the little piece of plastic in the port
  5. Guess I missed something. In times when pluto was a planet hacks used to be like turn a toaster into a lawnmower or something and not soldering a dull cable on a dull plate, thats what im doing every second day. I’m sorry to tell u, this is -atomic- fail… if u cant find hax better than this… learn to internet?
  6. Stop beeing so negative! If you think you can do so much better, then stop bitching, start your own website and find 7 _MINDBLOWING_ hacks every week!
    I do agree that the word “hack” does no longer mean what it did in the 80’es, but small stuff like this and yesterdays posts still might give the ol’ brain a little kickstart. Not to mention people who could never, ever even consider building an XBox 360 laptop no matter how impressive it is to read about online! =P
    Go hackaday, my favourite site online! =D
  7. the readers of a webpage based on reader submissions are the ones complaining that the submissions are showing a trend to sub-quality… personally if its useful for someone than its noteworthy and i enjoy reading them.
  8. I don’t think this is an XOR situation… no need to choose between the über-impossible and the simple but useful… just post two hacks at once.
    Surely google+user submissions is enough material to have two hacks posted occasionally?
  9. I agree that this is not the most difficult hack. However, it is smart and cheap and made the authors life easier. Since it has now been posted here where more people will see it, and it is so cheap and easy, it will probably make more peoples lives easier. I have no idea how hard it is to find good hacks on the web. But maybe we could dedicate one day a week to “mini-hacks.” Say every Sunday we could get a 6 pack of these.
  10. So i think this is an awsome hack. actually, idont. however the concept is great. I kinda wanna buy new ends for most anything i own that plugs in, cut off the xisting ones, and solder in the wires directly, hot glue the be-jesus out of it, and call it the indestructible connecter. if the laptop is at wierd angles on you lap, you can put stress on the little nubs that could break the connector or worse, the port somewehre inside the computer. with this, there is so much less to catch or tweek and torque. imho, this hack is a 8 out of ten, just for the concept.
    its easy to make something complicated, but goddamn impossible to make simple.
  11. nice hack. i would like to see a more… scavenger way of doing this but its a good hack.
    i think i might just have to make one of these.
  12. (sigh)
    far too much bitching going on on this site anymore
    It’s a cool mod and is useful for it’s creator.
    this is hacking, kids. we ain’t saving lives here so quit being retards and fraking roll with it!
  13. it stops your usb socket or plug from getting damaged. by making it not stick out.
    having a usb stick out the side of a laptop makes it very easy to damage it
  14. I don’t know why everyone has to be so negative about this mod it’s a great hack.
    Pros: protects port from damage,protects devices from damage, allows you to keep devices plugged in during transport of laptop, saves time (don’t need to stop the device and remove it, can be redesigned to fit your laptop and your needs, very low profile.
    Cons: prototype, design shown can cover open ports.
    Any improvement (function,design,style,look,use)on someone’s creation is a mod/hack.
    For those who said positive things thank you for those negative people 1)have you ever mod/hacked anything 2)you have modded/hacked something and are just conceited or jealous cause you didn’t think of it first.
