Animated X-mas Sign
Sure, it may be two and a half months until Christmas. That doesn’t mean we can’t start building a few Christmas decorations. Last year, [RB] over at Embedded Lab made an animated Christmas sign using a simple microcontroller setup. This year, [RB] is adding a blinking LED border and doing the entire project with 74xx ICs.
The letters for this year’s sign were recycled from last years’. This time, however, two strings of 12 LEDs are used for the blinking border. The blinking circuitry uses a 74hc14 Schmitt trigger to provide the clock. A pair of 74hc595 shift registers turn each letter on one at a time. The speed is controlled with a small trim pot.
Using ICs to drive a series of lights in a pattern isn’t a new thing – you’d be hard pressed to not find a similar setup in the blinking panels of sci-fi shows of the 60s and 70s. Of course this sign doesn’t compare with what can be done with a microprocessor a lot of patience, it’s still a very nice build. Check out the video after the break to see the X-mas sign in action.
[youtube=http://www.youtube.com/watch?v=KPSQhY1g5dE&w=470]
One thought on “Animated X-mas Sign
  1. In case anyone’s interested in what can be achieved a lot of patience, the now dead you-tube video (rmgf60CI_ks) has been captured by the way-back machine, it’s about Christmas lights built by Carson Williams
Leave a Reply to wzhdCancel reply
