LED Retrofit For Vintage Edge-lit Numeric Display Modules
edge-lit-led-retrofit
This single digit display is an old edge-lit module that [Ty_Eeberfest] has been working with. The modules were built for General Radio Company and have a really huge PCB to control just one digit. [Ty’s] modules didn’t come with that driver board, so he was left with the task of controlling an incandescent bulb for each digit. After a bit of thought he figured it would be much easier to just replace the edge-light bulbs with a set of LEDs.
We’ve seen these exact modules before, referenced in a project that created an edge-lit Nixie tube from scratch. Each digit in the display is made from a piece of acrylic with tiny drill holes which trace out the numerals. The acrylic is bent so that the edge exits out the back of the module where it picks up light from the bulb. [Ty] laid out his circuit board so that each LED was in the same position as the bulb it was replacing. As you can see, his retrofit works like a charm.
[Thanks Brian]
20 thoughts on “LED Retrofit For Vintage Edge-lit Numeric Display Modules
    1. What I actually find annoying is that you don’t immediately see where you were reading the thing on the main page so when clicking through you end up reading the first part twice, and that’s annoying.
      So I think we need some sort of arrow to show what part you already read.
  1. does anyone have any info about how these displays channel the light to illuminate the digits? the layout isn’t making sense to me, but it obviously works perfect…
  2. Edge-lit displays may be interesting and cool and steampunk and everything, but they are NEITHER NIXIE NOR TUBES.
  3. At first I went the usual HaD route of wtf man but after reading the article have arrived at “Kudos, Man!” Definitely an interesting read. Keep on tinkering :)
  4. Awesome! I have a bunch of these with tiny “grain of wheat” incandescent lightbulbs in them. Although I also have a supply of such replacement bulbs, I like this energy-saving replacement!
    1. I also have a bunch of older vintage displays that have a ground-glass front surface, and each lightbulb is covered by a transparent digit mask and a lens, They rear-project digits onto the front surface. I should be able to upgrade them the same way as these. Now I have a reason to dig them out and use them in some “steam-punkish” contraption. :-)
      1. I know I’m three years late in replying, but I had a Zenith 21″ TV from the early 1950s with a turret tuner. Each position on the tuner had a place to put a transparency, and a bulb and lens behind that projected this onto the middle of the channel knob. I know I’m not describing it well – here’s the model http://okhistory.org/blog/wp-content/uploads/2009/08/tv.jpg, the channel knob is the one on the right, and the dark circle in the middle of the knob was the projection screen.
        This allowed you to purchase tuning strips (which came with the transparencies) for the channels available in your area, including UHF, and not have to skip through unused channels.
