Mechanical Scorpion Robot Is A Cute Little Critter
Plenty of robots stick to a pair of driven wheels to keep locomotion simple. If you’re bold though, or just like creepy crawlies, you might instead appreciate this cute scorpion robot build.
Real scorpions have eight legs, but this design has just four legs, which keeps the parts count lower and control much simpler. It still looks a bit like a scorpion, though, by virtue of its cute little tail. It’s not just for show either—it mounts a camera which can be positioned at different angles via the tail’s servos. A Raspberry Pi Zero W is the brains of the operation, and allows the robot to be controlled via WiFi or Bluetooth.
Naturally, there is some additional complexity to the walking design. A full ten servos are used across the multiple legs and tail linkages. Most of the parts are 3D printed, however, so it’s quite easy to build at home once you’ve got all the parts to hand.
The robot critter has a shuffling gait, but we’d love to see it modified to walk and climb in different manners with the right programming and mechanical modifications. We’ve featured some other great creepy crawly builds over the years, too. Video after the break.
One thought on “Mechanical Scorpion Robot Is A Cute Little Critter
  1. No matter how much programming you do, you can’t have much better gaits with this leg configuration. You would either need to add four more servos, to have a proper 3-degree of freedom per leg, or have the two servos arranged in parallel, instead of orthogonal, to be able to do inverse kinematics at least in one plane, and forsake the sideways movement of the legs (it can still turn like a tank then).
    As it is, the legs move in arcs, which makes it impossible to move the robot in a straight line.
Leave a Reply to deshipuCancel reply
