A Network Status Panel The Way It Should Be
Sometimes a project forms itself around a component rather than an idea, and thus it was that [Maximilien] found himself building a data rate monitor for the connection between two data centers. Some MD0657C2-R LED dot matrix displays for not a lot needed a project.
The displays are mounted in groups of four on small PCBs, driven by a MAX6952, which are then controlled by a Pi Pico. There are several display panels in the project, each of which is a pained and laser-etched acrylic sheet with a pair of the LED boards mounted behind it. These in turn go on the front of a wooden enclosure, with a set of LED ring lights behind to illuminate the etched parts of the panels. Each display panel has its own Pico, daisy chained together and driven by a Pico W that supplies network connectivity.
As you might expect, this isn’t the first status panel we’ve brought you over the years.
16 thoughts on “A Network Status Panel The Way It Should Be
    1. Yeah, it’s nice and all but definitely not “The Way It Should Be”.
      I mean just ~10% are actively used – the rest is wasted real estate.
      A) very small labels/names
      B) the arrows are not very distinct(? dunno if that’s the right term)
      And weren’t there some analog-style meters? Those are much closer to “The Way It Should Be”.
      Numbers must be read.
      An analog meter’s deflection can just be “seen”.
  1. cute attempt at an idea, marginally constructed, a lot of effort but if it is not dedicated to you (which I doubt you have 2 private datacenters to monitor) expect it to be discontinued after you are asked to leave providing a golden trophy to the managers
  2. I like the look of those displays, but maxim chips are pure madness. MAX6952 costs around USD 25 both at Mouser and Digikey. And the whole thing can easily be replaced by a 50ct uC a hand full of resistors and maybe some extra transistors for the higher current common lines.
    MAX7219 is also popular on chinese multiplexed displays, but it’s “fake” but affordable and “works”. It has two mayor pitfalls. It needs a pullup / pull down resistor on one of it’s pins, or it may start up in a defective state, lights the whole display, and a power cycle is the only way out (which does not help without the resistor). The other mayor limitation is due to Maxim design stupidity. Brightness control is extremely limited. You can not use it to adjust the brightness depending on the light level around you. It’s barely sufficient to adjust for LED efficiency. With even a small 50ct uC, you can easily get 12 bit PWM, which gives you fine control over around 70dB.
    1. In my opinion hacks are supposed to unlock function we were originally denied, we’re supposed to make the very most of what we already have. This isn’t a hack! What is it hacking?! Hacking implies that we operate on something already existing, not add to the mountain high junk pile. I’ve been nice enough – any more will doom us all!
    1. You’re suggesting I abandon my own values because I challenge something? Not negativity – more like the voice screaming stop killing our children’s future for your own wasteful attempt at being the past back. Yes it looks nice, but where would humanity be if we if that’s all we considered.
  3. I have some projects on the go that have no purpose other than to entertain/educate me while I’m building them and then look cool on my shelf when they’re done. Let me know when we can set up a call so I can get your stamp of approval/denial – I imagine you’ll soon be very busy, what with refereeing all the projects here and on the wider internet, so I want to make my appointment before you’re booked solid.
    1. Maybe you should re-evaluate your priorities then and realise that you are just trying to impress others with something that “looks cool” rather selfishly. To think of the minds being wasted on entertaining one’s self’s rather than contributing meaningfully. I’m so frustrated that we STILL live in a totally unjust world and technological solutions that can fix it all are just being ignored for (personal gain) something cool to show off to friends. I’m sorry, I’m drunk, peerless, and abandoned by this society, I’m venting but not without cause,
  4. I’m a little surprised how much vitriol is being thrown the maker’s way for what is, really, just a nice little project and is fairly nice looking. Quibbles about uC choice aside, maybe. Gets too close to religion for me. :)
    And latency monitoring is always important for good service. I have tales…
Leave a Reply to PaulCancel reply
