LEDs are amazing things. As time marches on, they are being used in more and more lighting applications – everything from household bulbs to automotive headlights. But the push for smaller, cheaper, and brighter LEDs seems to have hit a snag for some of the less reputable manufactures.
Case in point, [bigclivedotcom] has been testing of some 100 Watt LEDs from eBay. When these LEDs work correctly, they put out a face-melting beam of light that you wouldn’t dare looking into (picture the scene from Raiders of the Lost Ark). They also have some unusual specs for an LED, like running on 30 Volts – and that’s a lot compared to the forward voltage of most LEDs at around 2.5 volts@20 mA.
So what gives? Well many of these high-wattage LEDs use a string of several LEDs in series. And as [bigclivedotcom] points out, this can be a real problem when a few of the LEDs begin to fail and act more like a low value resistor than a typical LED. In the videos after the break you can see [bigclivedotcom] test the LEDs to get a better look and what’s happening and why.
Continue reading “Why 100 Watt EBay LEDs Are Not Your Friends”
