UPDATE: Listen to the segment here.
Did you know I’m going to be a guest on NPR Science Friday today? If this is the first you’re hearing about it you need to sign up for the mailing list (there’s a sign-up form in the right hand column of this page).
If you’ve already listened to the show and found your way here for the goods on the projects, don’t worry. We’ve got you covered. Join us after the break for project links and details.
