XBox HD-DVD-ROM on Mac and PC
HD-DVD drives are getting closer, but aren’t terribly easy to come buy – yet. [Dan] over at uneasy silence let us know that he cracked open an XBox 360 HD DVD Drive and plugged it into a windows box and a mac. With a light application of some drivers, they got the drive working pretty easily – the snag? You’ll need a mini-ata adapter if you want to mount it internally. (And there’s apparently no HD-DVD software support for mac… yet.)
[you can just use it as a USB drive.]
Comments
  1. fucter says:
    you don’t need the adapter, only if you want to put it inside a tower case.
  2. wolf says:
    only a couple of days after its release, nice…
  3. TJ says:
    You only need that adapter if you want to mount the drive internally or put it on the IDE bus.
    If you are content with using it over USB, then according to the article you just plug it in and load the drivers.
  4. ravuya says:
    I thought DVD Player for Mac OS X supported HD-DVD, or maybe that’s just for OS X 10.5 — but I certainly remember reading about it before.
  5. ravuya says:
    Actually, according to http://www.apple.com/macosx/features/dvdplayer/ we can play HD-DVDs. Maybe it just doesn’t support the copy protection yet, or something.
  6. japroach says:
    Anyone find it interesting that the drive isnt SATA? Ok not that interesting, just that I would prefer a sata drive to an ide..
    It’s probably easier and cheaper to make an IDE to USB adapter, instead of sata to usb.
  7. ravuya says:
    Data transfer probably isn’t fast enough to justify SATA.
  8. jimmy d says:
    this might not be a bad option for the early adopters, but I think I’ll hold off until I see what kind of prices a internal read only HD-DVD drive is going to level out at. 199 is pricey for no burning capabilities (granted HD-DVD is a new technology) but I’m content with DL-DVD until I can get the drive that will both read and write.
  9. Marukka says:
    I dont think that drive is SATA, the adapter picture shows a 40pin PATA connector. Comments on the site which hosts that HOWTO say its a mini ATAPI connector. Anyways you can get these adapters from old iMacs, they all use laptop optical drives and have adapter boards on them to give a normal 40 pin PATA connector.
  10. If you want to convert avi to zune, rm to zune, rmvb to zune, divx to zune, vob to zune, xvid to zune,
    wmv to zune, asf to zune, or other formats to zune, you may need Zune Video Converter
  11. If you want to convert avi to zune, rm to zune, rmvb to zune, divx to zune, vob to zune, xvid to zune,
  12. omidzamani says:
    saft war for hack
  13. David Rose says:
    looks like my hd-xbox dive needs driver installed are there drivers that’ll work for pc-windows it works usb but not well.
  14. corey says:
    Has anyone actually tried the addaptor. my drive works fine with usb, however when i hook up to the ide the disc isnt seen.
    Any help?
  15. john says:
    is playback smooth? i have heard reports that playback is jerky.
  16. Ken Hansen says:
    Drives are now $50 since HD-DVD support dropped my Mfg. (Toshiba). That makes this a nice, USB-powered DVD drive for general PC/Mac use, and possibly HD-DVD player (with proper drivers, haven’t tried it yet)
  17. MTS Converter software converts digital files into a format such that you can easily edit videos recorded using Cam coders.
  18. You only need that adapter if you want to mount the drive internally or put it on the IDE bus.
  19. Convert Flv says:
    No doubt FLV format has quickly established itself as the format of choice for embedded video on the web.
  20. steven605 says:
    Just have a try with the powerful mts file converter, MTS Converter can be done perfectly!
  21. My goodness what an incredible job you’ve done here with this blogging site. This is the best blog page I’ve been to on this subject anyplace. Kudos for this tremendous written content and I will certainly be coming back and seeing you again in the future.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
