Autofocus Assist Light
afassist
[Aki]’s Nikon D2H did not come with an autofocus assist light.  His other cameras have them, and he likes the feature, so he decided to hack one into his D2H. He wired into the AF system, so that his LED gets voltage when the shutter release is pressed half way. The circuit needs refinement though, he found that the light was staying on during shutter release and affecting his light metering. You can see the hack in action after the break.
[youtube=http://www.youtube.com/watch?v=apuAG0CcG0I]
11 thoughts on “Autofocus Assist Light
  1. sorry.. grammar alert “…release and AFFECTING his light…”
    Effect is something you can do (sound effect)
    Affect is something that can be done to you (sound affected my hearing)
  2. i like the project. it looks like a good start, but yes, it should only activate the light on half-down. when the shutter release is pressed the rest of the way, the light needs to shut off so it doesn’t mess up anything in the foreground (say a bug flying by at night). very nice work all around. I could use one of these also.
    oh, and can something be done about the trolls? e-mail the editor, don’t spam the comments… (plz don’t flame me).
  3. Does the light from the LED when the autofocus is activated alter the camera’s auto-whitebalance and/or shutter speed to compensate for the extra light (which goes when the photo is finally taken)?
    Or does the camera do it’s light level checking after the autofocus stage?
  4. Thanks for featuring.
    haku: whitebalance issue doesn’t bother me as I shoot and use only raw, I fix the WB always in post.
    The light does trick the camera a bit with exposure calculations as it is on all the time when the button is pushed down and that is why I’ll put the led simply behind a separate push button on the side of the light on the next version (takes the power from the camera anyway) so I can turn it on with left hand’s thumb only when needed.
  5. How about buying a promaster flash with autofocus assist light.
    I got one for that same camera for less than $39.00 on ebay. got a better flash and a autofocus assist that works correctly.
Leave a Reply to fartfaceCancel reply
