Halloween props: Low cost popup
[Backroads] has put together this nicely detailed writeup explaining how to make a low cost popup prop. He’s using a single pneumatic valve and a home made PVC piston to raise and lower a scary mask. He’s using an off-the-shelf 110v AC valve controller to control the valve. A flickering light, a “screamer” and a fog machine help fill out the project. The result is quite nice. We would be tempted to put a pressure sensor in front of it to optimize the scare timing.
Comments
  1. spacecoyote says:
    He should decorate the garbage can.
  2. Nigel Spowage says:
    He doesn’t mention where the compressed air is being supplied from, any ideas?
  3. sly says:
    a compressor :p
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,513 other followers
