It is basically a nice compact layout for an Atmel Atmega 328 with a wireless module. Fully compatible with the Arduino IDE. The JeeNode is available in kit form, but also all schematics and CAD files are available to download. It looks like they are mainly using it for home monitoring and control. So far we’ve seen them put a temp sensor, power metering, and IR LED modules on their flickr set.
Subscribe for weekly videos
What about just using a Zigbit module? They’re basically ATMEGA chips with a built-in Zigbee radio + AMP. In the UK they cost about £25 from Farnell. Maybe this JeeNode is cheaper?
A JeeNode (kit) costs €17.50, which is under £16– crazy cheap! ZigBee is fantastic, but too expensive for many microcontroller projects, thought the ZigBit module really brings down the price by integrating it with the controller. Wish I could find availability in the US though; min. quantity 122 at Mouser! Anyway the JeeNode comes preloaded with the Arduino bootloader, so… er [ducking].
@salsa
Have you tried DigiKey? They seem to stock Zigbit stuff at a fairly reasonable price:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=3539948&k=zigbit
My Zigbit module arrived from Farnell yesterday, but I’m too scared to open it because its shipped in like 20 layers of ESD packaging!
Am i reading http://news.jeelabs.org/docs/JN4%20pinout.png Correctly? 4 DIO pins and 4 AIO pins? and no PWM? Here I was hoping for a good base to build an RC car on (yes i know RC car kits are available, but i wanted to build a mini car, not assemble some plastic)
@Cynyr
If you want IO, the ATMEGA644P is the way to go. Check out the Sanguino project. The ATMEGA644P gives you two serial lines, which means you can hook up any radio transceiver in addition to a GPS unit or other serial device without having to use SoftwareSerial. Win!
@Cynyr
Certainly fewer ports overall. However, if you look at the full documentation at http://jeefiles.equi4.com/JeeNode-v4.pdf it says that two of the 4 DIO pins allow PWM.
If you want a small form factor on the arduino platform, but more pins, you could always pick up an Arduino Pro Mini (or a Sanguino as Simmers suggested) and a wireless module and make your own.
@salsa
I got mine at Modern Device they are the US supplier for Jee boards.
http://www.moderndevice.com/products/jeenode-kit
@Simmers
That looks interesting, thats alot of extra IO.
@Seanstoppable
ahh, I didn’t look at the pdf, too much extra work on chromium on linux.
I found http://store.gravitech.us/arna30wiatp.html a while back, it’s a 328 with the ardunio bootlooder, in a small package. definitely not a self build, but small and retains the usb port and fits in a breadboard.
@Cynyr (and everyone), of the 18 normally available Arduino pins, JeeNode only uses five for the RFM12B interface– D2 and D10-D13. Ports 1-4 each have 2 pins, plus they share D3 (also PWM), so that’s 9, plus two each via the I2C (A4, A5) and SPI (D8, D9) headers: 13 pins are available, plus TX and RX.
Anyone know if these work with the US model (915 MHz) of the TI Chronos watches?
@theb
The RFM12 can transmit and receive on the 433MHz, 868MHz, and 915MHz using the software included on the ATMEGA. I don’t know anything about the TI watches.
you really need a pair to justify the wirelesss.
What else can you talk to?
really like it,, can be remove a circuit but we make repair system by incoders…
@anthonyn
Modern Devices also carries a JeeLink, essentially a stripped down Jeelink with USB and a large flash memory (for when the computer crashes). Modern Devices is having trouble delivering at the moment.
@Cynyr
The “IRQ” pin is PWM pin 3, the downside is its repeated on all 4 “ports”. I didnt look where the other 3 go, as I only needed 3 at that moment.
I’m the one working with them, thats my picture up there. Jean Claude (the originator) has done much more, and I’m following in his footsteps.
@Cynyr..
Forgot to mention, those are just the pins conveniently broken out and put on receptacles. You can get at the others, they are brought to pads and you can also tack solder directly to the 328. Its essentially an Arduino, on a thin board with different terminations.
