Update: 50MHz to 100Mhz scope conversion
Changing this 50MHz Rigol oscilloscope into its larger, more expensive brother just became quite a bit easier. When we originally looked at this hack it required pulling some capacitors off of the board. Now all it takes is three commands over a serial terminal connection.
Take a look at the walk through video after the break. You’ll see that there’s one chip that needs to be setup differently to change the functionality. Removing capacitors was actually changing the commands sent to initialize that chip at power-up. Now you can just change the model number and one letter of the serial number via a terminal and the firmware will recognize this as the more expensive DS1102E.
[Thanks Nullkraft]
Comments
  1. Hirudinea says:
    So the company can just reprogram the thing comming off the line and make you pay through the nose for it? What a rip-off!
  2. Luke Skaff says:
    I really hope someone finds out how to do this on the 4 channel version!
  3. grovenstien says:
    @ Hirudinea my sentiments exactly!
  4. asdf says:
    This is a very common practice. When possible companies design boards that can be used to build different models so they get heavy discounts by ordering great quantities of the same components and/or by resorting to as few production lines as they can.
    Sometimes they just don’t add the components of the bigger models so you see empty spaces on the board (just open your PC/mediacenter/cellphone/router/whatever), sometimes two models are totally identical save for a firmware setting and you get something like this scope.
    If you ask any suit about this practice he or she will answer that selling the 100 MHz capable model at a higher price is what allows them to sell the 50 MHz model at a lower one, which is both technically true and a smoking pile of bullshit (companies caring for the customers? LOL!). It’s all about profit and nothing else.
    There are limits to this of course. A 500 MHz oscilloscope would use so expensive parts and designs that making a 50 MHz model out of it would be unprofitable, so expect to see this only in very similar models.
  5. Luke Skaff says:
    @Hirudinea,
    Most electronics companies do this, you see this in low end consumer grade camera all the way up to $100K lab equipment where you have to buy updates which are just keys to unlock features.
  6. sneakypoo says:
    Just finished doing this on my scope. Works a treat.
  7. anarKit says:
    “OUTATIME”
    Nice!
  8. DLC says:
    Yeah, I did the modification last night, no problems at all, now I just need to get new probes, since the ones I have are for 60 MHz max. :-(
  9. charper says:
    “Removing capacitors was actually changing the commands sent to initialize that chip at power-up.”
    Umm… I highly highly doubt this.
    I’m sure it’s coincidence that two solutions unlock the full functionality of this product. Likely either the capacitor approach was wrong (removing a high-frequency shunt filter will give better high-frequency response, but it was probably there for another less-nefarious reason) or these two approaches are only part of the full solution.
  10. PHm says:
    Hirudinea, I do not think that it is as “evil” as it sounds. My guess is that the model number is decided after the units are tested. The 50 MHz scopes did not perform good enough to be labeled 100MHz and therefore got the lower rating.
  11. Hitek146 says:
    For those of you that don’t understand why this needs to happen, please refer to the comments in the original thread where this has already been discussed to great length…
  12. osgeld says:
    too bad it wont work on my 20mhz 1987 beater
  13. Just ordered the 50MHz model, before they change it…
  14. PHm says:
    I see that I type too slowly, sorry for repeating what Luke and asdf already said.
  15. John says:
    We discussed this the first time around. Sometimes it’s units that have failed testing, sometimes it’s cheaper components on the same board. No guarantee that your modded scope is actually accurate anymore.
  16. MS3FGX says:
    @charper,
    The exact method and reasoning behind both methods are detailed in the posted video.
    As usual HaD has misinterpreted the situation slightly, but not by a whole lot. The capacitors were part of a circuit that controlled which operating mode the scope would run in. It was found you could either manually force the mode by changing this control circuit, or simply change the model number in which case the firmware would change mode on it’s own. They both do the same thing.
    @PHm,
    That seems very likely.
  17. shiekh says:
    Does the modified unit update with the 100MHz firmware?
  18. DanS says:
    @John
    Sometimes they are just gouging you on the more expensive model.
    The simplest solution is usually the correct one. ;)
  19. DLC says:
    I work for a company and sometimes we do the same: enable and disable features by software, but it is not because they didn’t perform well on testing, it is because R&D and logistic expenses are lower designing one product only, also depends on some target markets, etc. Probably Rigol wants a product on the 20 to 50 MHz range, if they have nothing on this market they can loose sales here. Only they know the true, people that have made the modification have run some testing and the units does not perform bad on higher frequencies. I was waiting until the first guys made the mod and test the changes to change mine.
  20. jeff-o says:
    Excellent. I received mine a few weeks ago; I’m glad I waited to mod it. A software hack is far more appealing to me, since I can easily put it back the way it was if anything starts acting weird.
  21. JoeD says:
    Gotta love it — amazon.com lists both the DS1052E and the DS1102E scopes under “Tools & Home Improvement | Lighting & Electrical” :-)
  22. pixel says:
    He sounds so crazy
  23. therian says:
    Because HaD just cant keep it mouth shut, new version of Rigol will have this fix, you will see
  24. Cool,
    now I’ll just have to wait a few extra weeks for a software mod to change my DS1052E into a 4 channel version :)
  25. DLC says:
    @therian
    Seems like it’s already fixed. Visit EEVBLOG forum and you will see some comments.
  26. John says:
    @DanS
    Oh, definitely. It’s just that we don’t _know_ that it’s a gouge, and sometimes you really, really need your scope to be reliable.
  27. Richard Nibbler says:
    These guys have ZERO clue what they are doing. —-Last time they thought the cap they were removing was filtering the signal. Stupid hackers. I’ll keep my scope the way it is. Accurate.
  28. BiOzZ says:
    yah … they make money off professionals … like the nikon D3 12.2mp is $5g and the D3x 24mp is $8g for same camera different sensor … you can buy the 24mp sensor for $50 … it only really effects large companies according to them
    a majority of cases thats right
  29. chippy says:
    well did 100mhz firmware mod, works great!
  30. DLC says:
    @Richard Nibbler, this is too tentative that you will ended up making the modification, you have nothing to lose and a lot to win, if you are not happy with the results, just reverted it back.
  31. Andrew says:
    In my experience with higher priced scopes (Agilent, Tek…) its very common to have pure software locks on features that are sometimes more expensive than the scope itself. Agilent uses a license key system to unlock FFT, MSO and protocol packages while TEk uses smartcard dongles to unlock similar features.
    What I find so amusing, is all of the comments about reliability and how this will affect the perfect calibration of this scope. NO ONE, has mentioned that RIGOL is cheap chinese knock off company just like UNI-T and that these scopes are 1/10 the cost of comparable Agilent or TEk scopes .
    Now to be clear, I don’t think this hack is a bad idea, just that if your worried about having a rock solid accurate/reliable scope maybe you shouldn’t have bought a chinese knock off to begin with?
  32. Richard Nibbler says:
    @DLC. I suggest you locate your brain, remove the shrink wrap, and use it.
  33. DaveJ says:
    @Andrew
    Rigol are not a cheap Chinese knock-off company. They are the 2nd biggest maker of oscilloscopes in the world (by volume). Agilent’s low end scopes are actually Rigol units with the Agilent name on them.
    Rigol’s ARE “rock solid accurate/reliable” scopes, they are just built down to a price. And they are obviously good enough quality for Agilent to put their name on it.
    Dave.
  34. Daniel says:
    Oh how I hate this guy – he reeeeally likes to hear himself talk…
    Nice hack though… :)
  35. poot says:
    Does this hack work on the Rigol DS1052D -> DS1102D Oscilloscope/Digital Analyzer ??? That would be sweet
  36. ross says:
    poot – nobody tried it yet that I know of, but probably. They’re the same scope, more or less. The difference in the MSO version is that there is an extra board plugged onto a header. The firmware is different, but probably not by much. Try it.
  37. EqX says:
    @poot, No problem in doing that.
    The DS1052D and DS1102D use the same firmware (DS1000 series).
    The only thing you’d have to do is to alter the typenumber and the serialnumber to the one of the DS1102D.
    Because the DS1ED** to DS1EB** swap won’t work for you, you’ll need to change it in: DS1EA
    EquinoXe
  38. DLC says:
    @Richard Nibbler:
    Good try Boss, and I’m not talking about April 1st. ;-)
  39. Richard Nibbler says:
    @DLC – get a better name. You loose.
  40. D- says:
    Perhaps it’s been done, and I haven’t seen it yet. Until any individual modded Rigor 50MHz scope is properly lab tested and found to meet the all specifications of the Rigor 100 MHz scope, it can’t be said that thatindividual modded scope performs as well as the 100 MHz model. I’m skeptical in that all the remaining components of the 2 models are %100 interchangeable between them. Until I read evidence that most all the modded inexpensive scopes meet all the performance specs of the more expensive scope, this is all a fantasy. In they event that isn’t the case Rigor really isn’t gouging anyone are they? Shops or manufacturers aren’t going to pay for more scope than they need.
  41. Hiski says:
    @D-
    Blaablaablaa, no one cares.
  42. gnorf says:
    @poot
    did you made the hack from DS1052D to DS1102D?
    I can not find the 0.2.2.2 firmware for the DS1052D downgrade. Maybe i found a file, but i do not know if it is the right file. Does anyhone have a MD5Checksum or the file
  43. gnorf says:
    i got a device with the old 0.2.2.2 firmware. The Hack works fine with the description of EquinoXe.
  44. v2kai says:
  45. Jim D says:
    What everyone seems to miss is the hack only extends the timebase selection. Sample rate, accuracy do not change. you could see 100 MhZ sampling with the un-hacked dso, it’s just cramped up up on the display.
    DUMB, it’s a display hack, not a sampling hack.
    I know, I have one, hooked it to a High-precision signal generator. same damn scope.
    get over it…
  46. Brian says:
    Anyone know if the DS1052D (logic analyzer model) can also be modified in the same way to allow 100Mhz operation? Has anyone done this?
  47. cornelius_nl says:
    DS1052D (LA version) converted no problem. Received 3.0.1 HW 58, upgraded to 4.0.1 with official firmware, then took old 2.0.2 firmware, copied first 20 bytes of the official 4.0.1 header (no ascii) and copied over the first 20 bytes of the 2.0.2 so 4.0.1 FW would recognize it, downgraded, the set :info:(model/serial/hardversion) and upgraded back up to 4.0.1
  48. Some guy says:
    It’s software. No-one calls it evil when a software company cripples a demo, or unlocks features in a higher end version. I see no difference.
  49. Clay says:
    has anyone purchased and mod this scope recently?
  50. chapas says:
    need a tutorial for DS1052D
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,308 other followers
