Make the wedding ring speak to her
posted Jan 5th 2011 2:14pm by Mike Szczysfiled under: digital audio hacks, wearable hacks
It’s a nice touch to engrave a heartfelt message on a wedding band, and my couples choose to do so. But you can say a lot more with a 20 second audio message. That’s exactly what [Luke Jerram] did by etching an audio track into this ring. He uses his custom-built hardware to playback the message, which you can see in the video after the break. The ring is an Edison Cylinder, which works just like a modern record player except that the media is on a spinning drum (the ring) instead of a rotating disk. We wonder if this would sound a bit better with a high-end cylinder player.
While you’re on [Luke's] page you might as well take a look at his image projecting ring as well. It has a color image slide on one side and a projection lens on the other. Wacky!
Nice but what the hell is the message saying…
