Can a Dippy Bird be used as a temperature sensor?
Dippy birds are the toys that teeter-totter back and forth as the beak of  bird-shaped body dips into a container of water. The felt covering the beak and head picks up water and, through evaporation, cools that end of the glass tubing. The temperature changes cause the dichloromethane to either boil off, or condense, shifting the weight of the liquid thereby pivoting the glass body.
The real question is, does the temperature of the water cause the toy to move differently, and can that be measured to calculate the temperature of the water? [Craig] put that query to the test, by designing an apparatus to measure the motion of a Dippy Bird. A photointerruptor was used to measure the motion of the body, causing an interrupt each time the tail of the bird passes in between the sensor and the emitter. For control data a DS1820 temperature sensor was positioned near the felt on the head of the bird, and a relative humidity sensor captured readings at the same time. Data from the three inputs was collected over a two-day period. Although not a precise measurement, the motion of the bird did trend in the same ways that were recorded by the temperature and relative humidity sensors.
Comments
  1. daniel_reetz says:
    This post made me realize that passive solar array movers and dippy birds are the same technology.
    That is really cool.
  2. David says:
    and you didn’t use the press release?
  3. Will says:
    Rube Goldberg FTW!
  4. Tom says:
    @Will:
    No Rube Goldberg in this project. The author had a theory and devised a way to test his theory automatically without having to stand there all day collecting data points.
  5. tantris says:
    it’s not just the temperature that determines how fast the felt dries again. it’s also the relative humidity (google “wet bulb”)
  6. that1guy says:
    Always remember: It is very dangerous to use your dipping bird to vent radioactive gas.
  7. 1000100 1000001 1010110 1000101 says:
    Now this is my kind of OCD!
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 94,586 other followers
