Matchbox-sized line following robot
pocketbot_line_following_robot
While they are not nearly as complex as their self-navigating brethren, building line following robots is no simple task, especially when they are this small. The creation of [Ondřej Staněk], this matchbox-sized line following robot is quite impressive.
PocketBot’s 48mm x 32mm circuit board also acts as its frame, supporting the wheels, motors, microcontroller and more. The brains of the operation is an ATmega8 microcontroller mounted on the bottom of the bot. A pair of wheels are driven independently using a set of mobile phone vibration motors that power the bot at speeds of up to 0.35 meters per second. Line detection is achieved by using three different IR sensors paired with four IR emitters located at the front end of the bot.
PocketBot also has an IR receiver on its top side, which allows [Ondřej] to control the robot, tweak its parameters, or calibrate its sensors on the fly using an IR remote or his computer.
The PocketBot might not be the absolute smallest line following bot we’ve seen, but it’s pretty darn close!
Continue reading to see PocketBot in action.
Comments
  1. Punkguyta says:
    Now that is just cool! I was wondering how you connected it for programming as I see a 4 pin arrangement near the edge of the board (usb?) Then I read that he does it with the IR, now that is pretty cool!
  2. Beat707 says:
    Congrats to the people behind it! Wish we could buy this ready on eBay… ;-)
  3. medix says:
    That’s pretty slick..
    I can remember free-forming these out of soldered paper clips and LM339’s.. ;) Not nearly as elegant..
  4. Brook Keele says:
    This is sweet! I could have a lot of fun with my dogs with this thing. :) I love how he can control it with the ir remote arrow keys.
    How is he using the vibration motors for propulsion? Are the heads of the motors directly spinning on the surface of the wheel? I can’t really tell.
    I would love to build one of these.
  5. Pete says:
    Reminds me of this guy. It took a while to find it again…
    http://elm-chan.org/works/ltc/report.html
  6. Brook Keele says:
    @Pete: That link explains how he’s using the motors. Thanks for that.
  7. Monty Werthington says:
    Fascinating. An excellent miniaturization of a classic project, that Ir update feature would really make tunning a lot easier. Another good project.
  8. Mark A says:
    It would look good if you left it in the match box with some holes on the bottom for the wheels to pock thru and a hole for the sensor.
    Then invite a friend round and ask him if he can see where you left the matches, then turn the robot on when he’s not looking.
  9. Pilotgeek says:
    -“building line following robots is no simple task”
    That’s supposed to be a joke, right?
  10. Chris Allick says:
    want!
  11. brad says:
    video clearly states 0.6m/s, not 0.35m/s
  12. El_AMPo says:
    Love the way they embedded the connector headers as part of the pcb. (cheap and small ICSP)
    Anyone out there with a compatible mini cable connector?
  13. andrew says:
    Wow. His page goes into some more detail. Nice work!
  14. EasternFireTail says:
    Awesome project! Would be cool if it was modified a little to go inside a hotwheel car. Mini-Robot army anyone???
  15. spiderwebby says:
    He’s made got a version 2 in progress: http://www.ostan.cz/PocketBot2/development_diary/
  16. Wouter says:
    I just love the amount of work he put into this project, everything is so well taken care of and the whole thing feels finished. My respect. Now make it available as a kit at toy stores, or Sparkfun.
  17. jwstolk says:
    I like the use of a magnet to make a low-friction, adjustable “spring” to pull the wheels onto the motors.
  18. wow, this is the cleanest design i have seen so far :) i love it
  19. KillerBug says:
    It is neat…but I wonder why the second version is still only two wheels. To me, the only point of something like this would be to stuff it into a matchbox car…and for that you need 4 wheels.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,427 other followers
