Fabricating hardware from the original arcade Pong schematics
original-arcade-pong-rebuild
This heavily populated PCB is a recreation of the original arcade version of Pong. That is an important distinction because the home version of Pong used a specialized chip to do much of the work. This is basically all stock logic, which explains the high component count. We wonder how many quarters it took just to pay for all 66 chips at the time?
[Pong74ls] was the person who took on this project. There is an original schematic available, but it’s incredibly crowded and rather difficult to figure out. Fortunately [Dan Boris] has already done a lot of the heavy work. He took the one-page nightmare and turned it into a sixteen page plan for building the original board (look for the schematic link under technical details).
Before the board could be laid out some redesign work was necessary. It sounds like some of the original chips are out of production and suitable replacements needed to be found. The board was then laid out in Eagle before sending the design off to a fab house. There was just one error which didn’t allow the ball to bounce when hitting a paddle while travelling downward. A couple of jumper wires fixed that right up!
[via Reddit]
[Original Reddit Post]
Comments
  1. n0lkk says:
    Nice work, but not completed yet or we weren’t shown it. Needs to be placed in free standing cabinet at comfortable bar stool height with a strong glass tap impervious to spilt beer,and booze
  2. Andrew says:
    This one was quite impressive, good work. Why did you switch from Express PCB to eagle?
    • Addidis says:
      The programs like that that I used could only order from the fab house that released the software. I might be thinking easy pcb, but I think perhaps they are the same. Eagle on the other hand you can export as you wish.
  3. solipso says:
    Is it possible to rewrite pong in VHDL for a CPLD, ie. XC9572XL? Would be nice place to start with PLDs.
  4. echodelta says:
    I remember seeing those boards for sale as surplus in the back pages of R-E or P-E back in the 70’s.
  5. Sora-tobu chiru says:
    Early example of home(non-comercial) pong without specialized chips:
    http://www.pong-story.com/eaus0576.htm
  6. TheMeh says:
    Meh, all those ICs could be purchased very cheaply (about a quarter a head) I betcha the PCB (looks like about 30x20cm) was pretty pricey though!
  7. Addidis says:
    Impressive work. Perhaps more because of the missing chips, and working in alternatives than any thing.
  8. biozz says:
    they should have just used an arm cortex A9 or a rhaspi back than -3-
    kidding ofc *21 and grew up on PS3*
    its a nice build and im a huge fan of logic circuits especially when they use logic to create an analog signal!
  9. Cyberteque says:
    That gave me cold shivers!
    I used to work on those, my first “real” job out of high school.
    Spent my days re-seating chips in sockets!
    If you want real horror, the original “Tank Battle” game had a board twice the size of “Pong”.
    Then everything shrunk and you could get “Pong” and “Tank War” on a AY-xxxxx 40 pin DIP.
  10. Caleb says:
    All I could think when looking at the boards is WHERE ARE THE IC SOCKETS! I help debug and fix things for people all the time and its so much easier when there are sockets and you simply pull out the dead chip and replace it.
    Awesome build tho. I always say I’m going to do something like that then I just read about people who go all they way and do it! Great job mate.
    • pcf11 says:
      What is the major cause you have found for integrated circuits failing? The only things I know of that kill them are poor voltage regulation, and trying to draw too much current through one due to improper circuit design. Beyond that I’ve never known one to ever fail. I’ve never seen a spring loaded socket be reliable though. They always fail. Machine turret sockets are more expensive than standard logic chips are too. But if for some strange reason I feel I need to use a socket in a design it is all I’ll use.
      If you really need to remove an IC you just cut off all it’s legs and clear the holes one at a time. There are no bonus points awarded for pulling out a damaged part intact. It is game over if you ruin the board though. Lots of amateur re-workers never understand this. I was taught by professionals though.
      • Chris C. says:
        I don’t think chip reliability from this era was as good as what it is now.
        Plus when you have so many, it increases the statistical probability that one will fail. I recall seeing a proposed supercomputer featured here built from simple logic chips. IIRC, it had something like 28,000 of them, with a MTBF of 22 hours!
        • pcf11 says:
          I have a lot of ICs from the 1970s I’ve never noticed them being any less reliable than today’s chips. Less capable sometimes, the old ones used a lot more current to operate, some I suppose have noise issues too. But if it works in a circuit, they generally keep working.
          You’re sure that 28,000 IC computer’s failures were all IC failures and not from other causes? I’d sooner believe solder joint thermal issues, or connector failures honestly. The high part count alone is what made it unreliable. I’m sure the folks that assembled it tried to do the best job that they could but I’ve seen what those old computers looked like and they were designed in situ.
          Back then you’d get a “new” computer from a manufacturer and you’d have to spend months rearranging things so it’d work! No one ever said anything about it because that was just how things were. If you were a geek you were just happy you had something to play with.
          So are you sure all of those failures were IC failures? Even if they were it could have been due to faulty design. But the odds of all of those failures being purely because chips were failing is vanishingly small. I’m sorry but I’d sooner believe it was roaches dancing in a conga line.
          • Caleb says:
            If that was his first revision of the board and the first time populating it there is a good chance he wired something wrong and will burn up a chip. Things like that happen when your first designing something. Especially for a hobby project.
  11. NewCommentor1283 says:
    wow
    just epic
    but i think even more epic is the repair…
    “just added a jumper” lol he probably means
    “spent days trying to find where in schematic the wrong signal would was”
    XD
    • Cyberteque says:
      the original Pong board had Kynar wire trace “patches” all over the foil side.
      Like most games of that era.
      One interesting point, the Pong board used every single gate, except for 1 or 2 NAND gates of a 7400, just like the original Apple II board, which Woz developed to play Pong on.
  12. pcf11 says:
    I heard a story about one of the early video games installed in a bar and the bar’s owner called the company that put the game in to report a problem. When the tech came to fix the problem he found the machine’s coin holder was so full no more coins could be inserted into the game anymore. It might have been Pong.
    • Cyberteque says:
      back in the 80’s that happened all the time.
      You’d get to a site and a 20 cent piece had ended up somewhere it shouldn’t have ‘coz the coin box had overflowed
      • NewCommentor1283 says:
        so THATs why all the old hats ALWAYS check the darn coin box FIRST when theres a malfunction!!!!!
        i always wondered why. at the time it seemed like the least likely thing to go, i mean nowadays you’d be lucky to find 10$ or 15$ worth of coins
  13. nice work :))
  14. Nate says:
    Putting the part numbers and reference designators *under* the ICs on the silk-screen layer is a bad idea. Once the board has been populated with chips, none of these numbers are visable.
    While the old schematic–as scanned–is a bit unreadable, there is still much merit in having the entire plan laid out before you on a single page. Otherwise you are endlessly flipping back and forth between 16 pages of separate schematics–each offering insufficient context to grasp the entire design.
    But still, this is a fun project, and the original schematic, some 40 years old, is still educational, offering insights in logic design and compromise.
    • SavannahLion says:
      Yeah, that is maddening when you have multi-page schematics. Even worse when you have nets that cross more than two pages and ZERO indicator as to what page it’s on.
      “OK, So C1A34 is on page 6 and 12. That’s good, but why does… Oh…. It’s on page 9 too? WTF? Then where does net B46AQ go? What the Hell? I’m missing a page? Oh, it’s back here on page 3… No wait, that’s B46AO…. Damn hand-written text.”
      It once took me nearly a week puzzling over where one net went off to before I discovered that A) it was in an entirely different book, B) it was mislabeled, and C) that that daughter card wasn’t even being used anyways. >:(
  15. TERRA Operative says:
    Any chance of getting the Gerbers etc for this?
    It would be awesome if I could put one together myself. :D
  16. Pong74LS says:
    Complete kits and PCBs of this project are available at Tindie.com Search for TTL Tennis.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,409 other followers
