everything else you wanted to know about diy kegerators
basic stamp introduction
another good basic stamp resource
some pictures apparantly of a gamecube embedded in a pc case
homemade aluminum ipod case. sweet.
duct tape ipod case. sweeter.
duct tape and lego hackers can get jobs too
bender costume construction notes (in german, click the arrows)
another german hacker starts his pc with an ignition key (german, pdf)
mpaa lokitorrent takedown
schneier on ecommerce security and a paid parking lot hack
I think the link-roundup posts are fine in with the regular hack-a-days. Breaking up the regular flow can be a good thing. Plus it’s like getting a bunch of hacks all at once, instead of just the usual one per day.
Perhaps you could appease the endless negative viewpoints by adding a small amount of editorial comment around each link, and formatting the annotated list as a paragraph or two, boingboing or slashdot style.
WTF, i did the ignition thing 2 years ago!!!! and I don’t have a link or anything. http://metku.net/modgallery/detail.php?id=319 (proof)
you just use one of the lock switches and wire it to the power button (in my case, I wired it right to the pushbutton switch, which was broken)
I’m pretty sure I’ve seen computers that came with key switches (in addition to a power button) a loooong time ago. All I can say is that the case would also have to be closed with security screws or pop rivets because I’d just open the side and tap the power pins with a screwdriver. I’ve seen computers locked down with bios passwords and giant thumbscrews in the back. Hello cmos battery.
