Bus Pirate Preorder 1 Ships
panelized-470.iijpg
A few weeks ago we held a pre-order for the Bus Pirate V2go, the first official Hack a Day hardware. We had initially hoped for a group purchase of 20 or 40 Bus Pirates, maybe 200 if it was extremely popular. In total, nearly a thousand Bus Pirates will be made.
The first 350 Bus Pirates (pre-order 1) have already been manufactured and tested. Seeed Studio has done a great job handling the orders, pre-order 1 should start shipping more than a week early. How long will it take to get to your mail box? It will vary for everyone, but our packages usually arrive from Seeed in 7 days.
Seeed sent us pictures of the Bus Pirate depaneling, programming, and quality control process. Check them out after the break.
panelized2.ii
A panel of Bus Pirates.
de-panelization-470
Depaneling, also known as cutting a big sheet into individual circuit boards.
visual inspection-470
Visual inspection of each Bus Pirate.
programming-470
Programming the unified bootloader/V0g firmware via the ICSP header.
testing-470
Testing the bootloader and terminal interface after programming the firmware.
QC passed 2-470
Completed Bus Pirates are stored on anti-static foam, we like the shiny quality control stickers.
before packaging-470
Individual Bus Pirates are cut out for packaging.
packed ready-470
Finished Bus Pirate packaged in an anti-static bag.
handling-470
A box of Bus Pirates ready for handling.
ready-Envelope-470
One Bus Pirate, ready to ship. This might be be yours.
40 thoughts on “Bus Pirate Preorder 1 Ships
  1. For one, I see a distinct lack of mounting holes. Maybe they could leave that little edge strip with a mounting hole on?
    And since 1000 where pre-ordered at the same time, a drop in price?
  2. What I would like to see is more articles on the pirate, I enjoyed those, I realise there is no incentive left for you to do that since we have already paid but if you decide to then that would be appreciated I think.
  3. Looks great – can’t wait for mine :-)
    Shouldn’t be too hard to mount – there’s enough space on the bottom of the borad for some double-sided foam tape to fix them down.
    Some suggestions as to a good place to get the micro clips would be good. I understand why they aren’t packed in – too many people with their own needs. The small clips that fit smt parts are expensive, the normal .25″ compatible clips won’t suit everyone, etc.
    It would have been good to have the option of a wiring loom – where we get a nice cabled tail, and could add our own clis at the end. Maybe the next round :-)
  4. Shiver me timbers! Mine is on da way. Should have it tomorrow or Saturday, coming to Jakarta via DHL. I have a misbehaving MAX7219 SPI driver that wanna make love to Bus Pirate.
  5. We have to finish the first two pre-orders before we can consider more. The second pre-order had such a long and loose lead time estimate because there’s nowhere to get 700 PIC24FJ64GA002-I/SO right now. It looks like Microchip is starting new production and more chips will be ready soon. We’ll have an update on pre-order 2 next week.
    This is pure speculation, but there’s a revision 4 of the 24FJ64 coming that corrects the broken hardware I2C module, the switch to the updated chip might explain the current shortage. A Microchip engineer mentioned that he already had R4 silicon this spring. Again, pure speculation.
    If pre-order 2 gets an R4 chip, then those lucky Bus Pirates can do some hardware I2C stuff that we couldn’t implement before because of the faulty I2C hardware in R3.
  6. My pre-order 2 has been sitting on my desk for a while now, I’ve plugged it into a couple systems and failed to get anywhere with a serial console. The “mode” light was lit, though the documentation indicated that it should not be lit before selecting a mode in the firmware.
    Today I finally wasted about two hours figuring it out. Apparently, it came without any firmware loaded, and I needed to “just know” to go upload firmware to my device. What exactly the “QA passed” sticker on the bottom means… I’m not sure.
    Anyway, anyone else who got a preorder 2, you need to go to buspirate.com (Didn’t know that existed until now) and there is other info at dangerousprototypes.com.
    -Jonathan
Leave a Reply to jake Cancel reply
