Building A Solar Power Heliostat
[Frits] has been working on an solar panel heliostat (in Dutch, check out the translated page here).
The heliostat uses a small PICAXE to control the motor, along with an DS1307 real-time clock to make sure the motors start at dawn. Instead of using optical encoders or magnetic sensors, the angle of the heliostat is measure with a pot attached to the drive shaft. [Frits] did a lot of data collection to figure out that this method is accurate to about 1 degree – just fine for something that doesn’t need to be exact.
According to [Frits] this heliostat will put out 12 to 50 percent more electricity than a fixed panel. Although the build does seem a little bulky, putting it on a  house with a roof pitch of 23.5° would greatly reduce the horizontal profile.
A video of a solar panel rotating at 15 degrees/hour isn’t that interesting, so [Frits] posted a clip of 6 mirrors slewing around fairly fast to demonstrate his system. Check it out after the break.
[youtube=http://www.youtube.com/watch?v=uOuJpzQQ9ic&w=470]
16 thoughts on “Building A Solar Power Heliostat
  1. Why make it look for and track the sun when you know exactly where it will be with respect to the earth? The hard work has already been done with altitude/azumith tables freely available online.
  2. >Why make it timed, make it
    >actually look for and
    >track the sun.
    No, thats bullshit. Tracking based on time is extremely accurate as the suns position can be predicted exactly. Measuring it induces error and wastes power if clouds make it jiglle back and forth. Timed is the only way to go!
    The build looks nice, but I don’t understand, why those people building these never consider the outdoor environment. This wooden thingy will just rot and rust and be broken apart by the wind.
  3. about the wood build: i think its a proof of concept? also: wood that is threated well can easily last 15-20 years, and is was greener to produce than some shiny aluminum extrusions.
  4. Call me stupid but wouldn’t it be more convenient if the panels weren’t mobile at all?
    If it was instead some sort of collector (satelite dish covered with a reflecting material) that would track the sun?
  5. Not a heliostat, that’s what we in the biz call a one-axis tracker. A heliostat is a device used to reflect sunlight onto a target (like in Concentrated Photovoltaic applications). Heliostat sounds cooler, I’ll give you that…
  6. Steve is such a professional idiot. Hi Steve!
    Too bad systems like what I am talking about is used in industry, and his claims are based on his lack of experience and wild ass guessing.
  7. Without a doubt you can get more power by tracking the sun, however it does have it’s issues.
    # More complicated system, thus more to fail
    # More delicate system (I happen to live in a fairly windy area and was concerned that a cheap mount would break and damage an expensive panel)
    # The majority of the gain comes in the summer when (if off grid) it is not required.
    Even if you are tracking, towards dawn/dusk you may not be producing enough voltage to be able to charge. I would suggest people series up the panels to a higher voltage and use a MPPT charger (to squeeze the twilight power out) before spending on tracking mounts.
    BTW I have an off-grid 1.3KW system in Southern Alberta.
  8. @fartface – think about it, clouds &c.
    More like 10% than 30%, and still pointless unless you have a whole field full of panels.
    Energy loss is proportional to the COSINE of the angle of incidence folks.
    @Nefario – panel manufacturers specifically warn against using reflectors or concentrators.
    @fartface is such a professional idiot with his wild arse guessing. Some of us really have got industrial experience and know why time tracking works better, but tracking generally only makes sense with industrial scale installations because of the COSINE factor. @Steve and @mungewell are on the money. I can vouch for the effectiveness of switch-mode Maximum Power Point Trackers in on-farm water pumping applications.
    Hi Fartface – your first comment marks you as a know-nothing troll.
  9. Here we go again, acting like throwbacks, fartface linked to an actual working hack and although the clouds arguments is good since holland is pretty damn cloudy people have to push it to a fight and then start throwing the ‘troll’ remarks around.
    Why not also throw in the nazi remark and end the thread while we are at it?
  10. A simple way to use solar tracking is to use a photovoltaic switch which gets turned on/off by an arm attached to the panel which casts a shadow. The switch controls a little motor… err u know what i mean
  11. Sorry .. for being a latecomer.
    The concept of coupling multiple panels to single drive is nice. Only thing is power( I mean total system of motor, gears ) for driving a large panel may not allow the use of simple drive shown.
    BTW ask any supplier for incorporating tracking and they say it is impractical. ( complicated /bulky/ difficult to maintain and so on )
    I think it has more to do with economics .. more efficient system means less number of solar panel sales.
  12. Old fiberglass C band satellite dishes make great Heliostats. Covered with mirror film, Target made out of aluminium scrap filled with a copper coil, 5 degree lag was required to keep from generation of steam. the collector size is 10 feet. Target depth or focus can also be changed for temperature regulation. I have less than 300.00 dollars in it so far I am using the 24v dish tracker to track the sun and trying to figure out how close to actual meridian i can come without steam generation. For a po boy project it has worked very well and the only drawback is the efficiency of this build it makes tons of hot water, enough for a family of five never a cold shower and I have 6 250 gallon totes plumbed together with spray foam insulation buried under my garage for storage however its also way too big. Could be half the size and it would be plenty im running water storage at 130 and using mixing valves for bathing. for heating i pump direct 130 degree water through a coil in the duct in front of the furnace to heat usually only with hot water. My last tank of propane has lasted 2.5 years the dual fuel heat pump rarely ever runs unless its very cold. At this point the rental of the propane tank per year is greater that the cost to fill it. Still siting at 70% so im figuring on at least 3 more years. My hot water tank has a solar pump and a cupperickel heat exchanger I salvaged out of an old commercial water cooled Ice machine.That provide domestic hot water for bathing etc.I have also piped hot water (pex) to my greenhouse to keep it warm during winter and it has never got below 40 degrees. Plants are flourishing. I just love this stuff!!! Get creative and you can make a system that will preform very well.
  13. Weeelllll
    I’m gonna be ‘that guy’ and suggest that what you REALLY need is a map, a calendar and a clock.
    Both timers and tracking are sub-optimal.
    A Raspberry Pi Zero (or almost any board) can calculate the precise position of the Sun given location data from IP, GPS or address entry and the time of day. Potential for community software since IP geolocation is sufficient to auto-calibrate.
    If desired, a simple light sensor could be placed, having the board log angle & light levels every 5 minutes.
    With each daily cycle logged, automatic adjustments based on local geography and obstructions would be automatic as well
    Also if desired, one could render the timing tables for a given location (with or without sensor data) and use timers if you really wanted, or if you wanted to have only one compute board and the rest simple.
    buuuuut that’s me
Leave a Reply to Garet B ClabornCancel reply
