Maybe it was a language barrier he ran into, or possibly an inclination to do things the hard and smart way, but we really like [Alessio]’s take on building the display for his word clock. Instead of relying on a pre-designed word layout, he made his own word pattern with a genetic algorithm.
While looking at other word clock builds on the Internet, [Alessio] noticed all the DIY copies used the same pattern of letters as the original QLOCKTWO word clock. There are obvious reasons for this, laziness chief among them, but [Alessio] decided to do one better. Armed with JGAP, he made a 10×10 German language word clock and a 11×11 English language word clock.
[Alessio]’s algorithm takes a list of regular expressions – ‘five past four’ and ‘four five’ are both valid expressions for 4:05 – and combines solutions together for a hopefully optimal solution. One added bonus of [Alessio]’s method is the ability to generate non-square word clocks. On his project page, [Alessio] put up examples for round, triangular, and diamond-shaped word clocks.
[Alessio] ended up building a 10×10 square German language word clock with an Arduino Nano, DS1307 real-time clock, RGB LEDs, and a few shift registers. Very nice work for a custom-designed word clock.
“regular expressions”
I don’t think that means what you think it means.
Take a look at his site. He does use regex:
1:00 : (.*?)(one)(.+?)(o)(.+?)(clock)(.*)
1:05 : (.*?)(one)(.+?)(five)(.*)
1:05 : (.*?)(five)(.+?)(past)(.+?)(one)(.*)
My bad, next time I promise I’ll read TFA before attempting to troll.
@MrX: The linked article gets it correct. That’s the issue you take away from this though? Not how cool the actual hack is? Give me a break.
Anyways, to Alessio: This is awesome! Great practical use of GA.
Looks clever. I’ve been looking to put one of these together based on a recent kickstarter project ClockTHREE.
Alessio has definately made this much more interesting. Very clever use of the regexp to solve potential matches. I wonder if it could be used to find Vertical as well as horizontal matches.
Just take the groupings that the program puts out, and arrange them vertically before you cut the stencil.
I intended to say it would be interesting if it could arrange them BOTH horizontally and vertically.
like so:
t
w
one
still, tis cool
“[Alessio] decided to do one better. Armed with JGAP, he made a 10×10 German language word clock”
He did not use JGAP.
“I just wanted to really understand the GAs and decided to program it *completely by myself*. For a real problem you would of course use one of the many GA frameworks (JGAP for example)”
I have been unable to leave a comment on his site, so I’ll post it here.
“Fourthy” and “fourty” should be changed to “forty”.
Also, I’d change the :05 times to (.+?)(o)(.+?)(five)(.*).
“Fourthy”? Neat idea, but I think something was lost in translation.
I don’t know where that sample came from. But I’m glad I’m not the only one that fell for it. Try looking for “three” ;-)
I guess it’s just a picture. Hehehe
Another word clock:
http://chriative.com/blog/projects/word-clock/
After reading through,I had to come back here and say:
I freakin love GA,ever since the mona lisa I’ve been craving for more.Also got a 2D vehicule GA trying to climb a hill.I still have em somewhere on my computer if you want em,they are offline now.. =/
4:05 is never “four five”, it’s “four oh-five”. If you’re an English speaker, that is.
Has anyone else been able to get his java code to run? I’ve had no luck at all so far.
This type of clock appears to be quite popular so it’s cool to see a different spin on it. I have to say that all of the pictures I see online are rather ugly though. I just finished mine, and I have to boast that it’s definitely the coolest.
http://www.augsoddsandends.com/Augs_Odds_And_Ends/Word_Clock.html
Thanks everybody, I corrected the “fourty” typo and changed the :05 times as suggested by Thopter and Andrew.
Whats the problem with the code? I just imported it in Eclipse and it runs without any problems….
I figured out how to run the code. It was my fault, my first time compiling and running java code on my computer.
I redownloaded the zipped code, but it’s the same as before. What changes did you make?
I didn’t really change the Zip file, I’ll do that if I don’t forget it..
The only changes where in the “TimeNamesEnglish.java” where the strings for the times are generated – just have a look at it, it’s rather short.
Yeah, I made changes in that file too. I didn’t see how to get the :05 though, without also getting “o five past three”.
I put the code up on github, so check it out
In case someone wants to fiddle with this idea in python I have made an implementation with DEAP at this link: http://dcandi.com/post/genetic-algorithms-deap/
