[taulman] over on Instructables has been working on his own version of a 3D printer. Unlike the usual PLA or ABS filament all the RepRaps and Makerbots use, this printer uses nylon to make parts with very interesting properties.
Most extrusion printers are designed to print with ABS (a very hard plastic that melts around 220-230° C) or PLA (a somewhat softer plastic that melts at about 180° C). [taulman] is using Nylon 6, a very slippery and bendable plastic that melts around 320° C (about 600 degrees Fahrenheit). He’s doing this with a hot end of his own design and a ‘spiky’ extruder bolt that allows high-temperature thermoplastics to be extruded into any shape imaginable.
For the longest time, the 3D printer community has been using low-temperature thermoplastics such as PLA and ABS. There are obvious benefits to these materials: it’s pretty easy to source a spool of filament, and the low melting point of these plastics makes building a printer easier and safer. Now that [taulman] has the high-temperature plastic nut cracked, he’s moving on to easily-machiniable Delrin and transparent Polycarbonate. Very cool, and hopefully in a year’s time we’ll have a choice of what material to run in our printers.
After the break, there are a few videos [taulman] put up showing his printer at work and the properties of his 3D printed objects. It looks like [taulman] can print objects that are impossible on any other 3D printer we’ve seen; the flexible iPhone case probably couldn’t be made on any other DIY machine.
[youtube=http://www.youtube.com/watch?v=LHTXhyh7X5s&w=470]
[youtube=http://www.youtube.com/watch?v=CPqRJ86e0jk&w=470]
http://goo.gl/FMP4X <– nylon printing december last year.. haven't done more because it smells revolting and emits hydrogen cyanide, carbon monoxide and other nasties… Need a garage that's not attached to the house so I can leave the prints unattended without risking poisoning my family
He did mention that the trimmer line gave of some noxious chemicals in on his page
Good call, triffid. While there are several nylon polymers, trimmer line is “required” to contain an amount of fiberglass and other chemicals to be sold as trimmer line. Chinese were selling raw nylon as TL and pissed a few off….
Technically, the fiberglass and added chemicals forces the temperature so high that it starts to burn the nylon and that’s where you get problems.
Fishing line also has fiberglass, otherwise it would soak up to much water and stretch to much.
I am sorry to be late to the party, but what is DIY state of the art for Delrin printing?
Try Nylon 12 filament from http://www.rdmfilament.com... No fumes, running at 230-260 C depending on the speed you want…. And some really good characteristics
This is an old article, but:
“taulman” says: “trimmer line is “required” to contain an amount of fiberglass and other chemicals to be sold as trimmer line”…
This is false, and if you are “the” Taulman, you are knowingly lying. Keep in mind that Taulman’s business is selling 3D printer filament and he has a vested interest in all of us thinking that only HIS filament is suitable for printing. Absolutely NOTHING requires trimmer line to contain any specific material, even Nylon. But it is fairly easy to find trimmer line that is pure Nylon.
Some higher-end trimmer line contains fiberglass and other reinforcing fillers to make it last longer in use on a line trimmer. But cheaper bulk round trimmer line is generally plain Nylon (either a blend or a copolymer), without filler, essentially just like Taulman 618. It does usually contain a dye, because trimmer line size is identified by color. If you want 1.75mm filament, you go for the blue stuff. Although it’s closer to 1.65mm (surprise, just like most of the Taulman filament I’ve purchased) it prints just fine, and can be had for under 1/4 the price of Taulman’s overpriced Nylon.
In a different post, Taulman claims that adding fiberglass makes trimmer line cheaper. This too is a lie. Fiberglass is cheap to buy but expensive to process. The process of mixing fiberglass into the Nylon, then extruding it into trimmer line, is MORE expensive than extruding plain Nylon.
(Here, he claims that “Chinese (sic) were selling raw nylon as TL and pissed a few off (sic)”. Mr. Taulman, when you lie, you need to remember not to contradict yourself.)
Fishing line (even monofilament) is not always made from Nylon. And Nylon monofilament fishing line often contains additives that would be undesirable in a 3d printer, but fiberglass is NOT one of them. Why do you make this stuff up? Habit?
Try real Nylon 12 Filament @ rdmfilament.com
Not very familiar with 3d Printing but it has always peaked my interest. Is there any reason one could not use Nylon fishing line filament or is it to thin? To me it seems to provide a nice consistent starting point.
*piqued
If it weren’t for the nasty chemicals this would emit, I’d be all over this. Good stuff though. Is there a safer material that can imitate these results?
Why are the fumes so much of a problem? You just enclose the 3D printer in a acrylic box and then put a exhaust fan and pipe to outside. Done, problem solved.
The chemicals it emits are toxic in very low quantities, as little as 10 ppm if I recall correctly. They are not something you want to mess with in a home built setup unless you know what you’re doing.
and pumping it out side doesn’t make the problem magicly go away it’s just hope it becomes someone elses problem.
Then you poison your neighbors.
tm, dex and octel have good points, so I want to address them. First, I think it’s great that all of you have an interest in this material.
The biggest problem with heating nylon is Not the nylon, but the additives and the main additive is fiberglass. Fiberglass is what gives nylon it’s strength at high temperatures and low densities.
Fiberglass is cheap and as an additive it reduces the overall costs of the part being made. A win/win for injection molding…..not so much for 3D Printers. The fiberglass and other chemicals added to fishing and trimmer line actually force you to raise the temp to the boiling point of the raw nylon to extrude it. That’s way beyond what raw nylon requires. And at those temperatures, all plastics become unstable. Add fiberglass to ABS, PLA, PET, even PVC and you’ll burn and boil the base plastic. Those are the chemical odors ppl detect. Understand that the car and truck industry love a low cost plastic that can take 230F all day long…..and when you add fiberglass to Nylon, that’s what you get. Great for cars, again, not so for 3D printing.
The solution is a nylon polymer that has a low melt point and is strong in and of itself. I am working with a large US Nylon mfg to design and test a polymer specifically for 3D printing.
If you want to see “strong” there’s a video I added to the instructable of a 8 lb sledge hammer striking a taulman nylon polymer part at 320 frames’sec.
Talking about the flexible iPhone case. Yesterday I just came across this,
http://www.shapeways.com/blog/archives/1375-Introducing-3D-Printed-Black-Elasto-Plastic-I-Cant-Believe-Its-Not-Rubber.html
Dont know if anyone else has seen it, but they have iPhone cases and other bouncy and flexible things..
I think their new rubber material would be too coarse and flexible. Their main material (WSF) is also nylon based and is quite flexible for cases (I know since I’ve made one with it: Tarsier.)
This site has flexible filaments http://3dprinterfilaments.com/rubber_%20like_filaments
You need to learn to not use the ALLSTEPS format in i’ble – it does not redirect to the relevant step for thoes without a paid i’ble account
Paid account _not_ needed… although you do need to register for a free account to see “All Steps”.
(Annoyingly, Instructibles has a __very short__ life login cookie. I use more than one computer so on whatever system I use, I am always needing to log back in. Grr.)
Someone needs to stop this guy before he poisons himself. PTFE degrades after 260c, and starts decomposing around 360c – it’s bio-accumulative, meaning the effects will slowly poison him over time , even in low concentrations.
That’s all very well, but what does PTFE have to do with this?
Because he’s using PTFE in his extruder, and running it at these high temps too. The pyrolysis of PTFE is detectable at 200 °C (392 °F), and it evolves several fluorocarbon gases[18] and a sublimate.
While PTFE is stable and nontoxic, it begins to deteriorate after the temperature reaches about 260 °C (500 °F), and decomposes above 350 °C (662 °F).[21] These degradation by-products can be lethal
Here’s also another good read about the Fluorocarbons released when PTFE is heated beyond degradation temps: http://en.wikipedia.org/wiki/Fluorocarbon
Look under “environmental and health concerns”
It’s good to see people keeping up on their Teflon.
I knew this going in on the design of the 2BEIGH3, so I designed the hotend such that the PTFE interface with the aluminum block was the smallest footprint possible. In addition, we did thermal gradient tests across the aluminum block from the heater cartridge to the nozzle and nylon heat chamber. The actual measured temp at the interface is 198.3c with nylon 6.6 and lower with PET and PLA. The plastic line you see from my extruder to my HE has a “TEE” where I pull a vacuum to reduce the nylons picking up water in the Hi HU air here. That also pulls a draft through the Teflon coupling cooling it. Please understand that I couldn’t explain a ton of stuff on the instructable site or I’d bore ppl to tears. Fact…the hot end is designed to accommodate, plastics thru nylon as designed. Other hot ends that I use for other materials, use a peek plastic interface. The reason is that my design will capture the temperature range of Bismuth, Tin and Zinc. And “yes” I have 3mm rods of Bismuth, Tin and Zinc!
So what, young man, would you say to an N or He gas sheath similar to what we do when we weld Aluminium? Does such a thing make the high temperature melting of such composite materials less prone to burning or other chemical changes? Or do these toxic gas emissions and/or more importantly, chemical instabilities, occur without the presence of O2?
I think this iPhone case could be cast relatively easy.
Those tempetures are high enough to use some metals like common solder with.
@thantik Ah okay. I must have missed that part in my quick grep through the article. That does sound concerning, although I’d hope he already has a decent extractor if he’s working with nylon.
Can’t do glass filled? Not useful.
very nice. you think you’ll sell it to me ?
my Brother and me are constructing a CNC-Multibot in modular type. till now its all “Pen and Paper”
but Im looking forward to start building it in half a year. in the end the thing should be easy and cheap to build and the “How to Build” shall be available for everyone for free in the www.
If there are some ideas just hand them in. Thx.
built in material shredder would be very nice addon feature
I am interested in outsourcing a nylon 3d project. Where can I go to do this? It consists of 24 pieces of ½ inch of window-slider-washer, closed on one end. Any ideas where to go?
If you look at 3dHubs they have printers located all over the world… You can find a local printer wherever you are located… Just signed up myself.
If you print parts yourself try http://www.rdmfilament.com for ‘No additive’ Nylon 12 Filament for your prints and Fubar Glue for the build bed….
