I set up a PWM output to just fade in and out when the button was pressed. I plugged each driver in, clipped the LED leads, and pressed the button. 800 times. Many had to be fixed. I think Benchoff suggested I do this, it hadn’t even crossed my mind. Glad I did. Many of the fragile drivers didn’t even make the trip to PA though, some silicon would have helped keep that wire in place.
