It’s not too late to hack your own Valentine’s day gifts. Here’s four projects to get you headed in the right direction.
Heart-shaped box
[Ian] built what he calls the Valentine’s gift bomb. It’s a cigar box with this LED heart on the top. A servo motor latches the lid from the inside and won’t open until the thing goes off on the big day. (sorry, no link to this one as he just sent us the pictures found after the break).
A Blinky Bouquet
[Ryan] shows us how to make a felt bouquet and then light things up with some LEDs.
Pictures in a bottle
Reuse that old incandescent bulb by adding LEDs and heart-shaped pictures inside the glass enclosure.
Robot love
This cocoa container turned robot cat calls, raises its eyebrows, and blinks the LEDs eyes when she presses the button on top.
The lightbulb guy put the LEDs in parallel without individual resistors. naughty naughty.
Doesn’t he put a 220 Ohm resistor between them and the battery?
When in parallel LEDs should have a resistor each. Because each will have a fixed vdrop as these age one will become very bright the other very dim (as heir vdrop’s diverge) and they don’t equally share the 40mA he’s providing (or whatever it was).
It’s just bad engineering practise, it’ll probably work for his intents and purposes.
Ha, I should have known someone would pick up on that, I updated the Instructable, thanks :D
A noteworthy piece, thank you from a fellow gaming addict!
