A Crystal Radio Amplifier In A Jar
The cool thing with crystal radios is that they are solely powered by the incoming radio waves. However, it usually means listening to your AM radio station with an earpiece and even then, depending on the antenna length, ground connection, and radio station, it can be quite hard to hear.
Even though it is cheating, [Steven] decided to make an amplifier for all the different crystal radios he had made over the years. His design, based on an LM386 amplifier was firstly tested on a breadboard and then permanently soldered onto a perfboard. To make the complete system easy to transport, he opted for a peanut butter jar where he embedded the speaker in the cap. The on/off switch and volume controls are mounted on the side, and easy alligator clips are used for the antenna connection.
The final result is not the one shown in the picture above as [Steven] painted the jar black, giving it a sweet look.
20 thoughts on “A Crystal Radio Amplifier In A Jar
        1. I went with Jujubes instead. Eating some as I type. :) I’ll try to put the image inline here but if it doesn’t work, just go to the webpage in the description above (I gave you credit.)
          [img]rimstar.org/science_electronics_projects/make_crystal_radio_amplifier_for_speaker/crystal_radio_amp_in_a_jujubes_jar.jpg[/img]
          1. Hey, that’s awesome, thanks for posting the pic! Now you have the ultimate survival radio for bushfire season. Evacuate home, drive somewhere safe, and listen to the updates on AM radio while living off the supply of jujubes :)
  1. Why not making a charging circuit with a super capacitor? While the radio is off, use the incoming radio signal to charge the cap. While the radio is on, the cap acts as the power source for the amp.
      1. It’s called energy harvesting, and it works fine. Parasitic effects in run-of-the-mill semiconductors can rob a lot of the bounty, though, so it works better with purpose-built silicon. There are all sorts of sensor motes and stuff using ambient radio signals for power, storing it up until they transmit a data burst.
  2. The lowest power method I know of, is a DC supply to forward-bias the sensor diode. You don’t actually switch it ON – just get it closer to point of conducting. For 0.2V germaniums, about 0.15V will increas sensitivity a lot. If you are using 0.6V silicon diodes, bias them around 0.55V.
    You don’t need a lot of current. A decent solar cell will do. Try something about the size of a Tic Tac box (the electronics go inside, glue the cell to the outside).
    1. I definitely have to try these. Thanks for pointing them out. I get asked a lot about using silicon diodes when they’re all they can find, and even though adding power to a crystal radio is cheating, I think a lot of students will find it okay for their projects if it gets it working. The solar cell approach adds a lot to the fun of it.
    2. Time and sunlight finally lined up for me to try biasing the diode as you suggest with a solar cell. I didn’t see any improvement. I tried with the cell connected both ways and I varied the solar cell’s output by controlling how much sunlight it was getting. I had fairly fine control and verfied the voltage with a meter. I retuned the radio each time. Theoretically I don’t see why it wouldn’t work. Maybe I just didn’t find the sweet spot. The stations I could get saw no improvement and I couldn’t get any new ones. Also, there was no change in volume in the noise. I’ll keep hacking away at it.
Leave a Reply to Blue Footed BoobyCancel reply
