We don’t mind it that there’s no chain connected to these pedals. At least there’s still somewhere to put your feet and our legs are too long to comfortably pedal this size of bike anyway. As you can tell, the added hardware takes care of locomotion using an electric motor.
The first step in this project was to find a steel bike frame to make welding a bit easier than it would be for aluminum. From there the paint was sanded at the attachment points and mounting brackets were fabricated from some angle iron. The rear mount houses a 500W 30A AC motor which uses a chain to drive the rear wheel. A specialty hub was found which allows the added sprocket to be installed on the left side of the rear wheel. Some threading issues prompted [Michael Monaghan] to come up with a method of adding a slot to lock the part in place.
Near the front fork the second mounting bracket holds the batteries; a pair of sealed lead-acid units. The speed control mounts on the top where the rider has easy access to it. The finished bike can get up to thirty miles per hour with a range of up to twenty miles between charges.
If you want your own electric bike on the cheap you can try building one from a salvaged washing machine motor.
