Getting into home automation usually starts with lighting, like hacking your lights to automatically turn on when motion is detected, timer controls, or even tying everything into an app on your smart phone. [Ken] took things to a completely different level, by giving his lighting intelligence.
The system is called ‘Myra’, and it works by detecting what you’re doing in the room, and based on this, robotic lights will optimally adjust to the activity. For example, if you’re walking through the room, the system will attempt to illuminate your path as you walk. Other activities are detected as well, like reading a book, watching TV, or just standing still.
At the heart of the ‘Myra’ system is an RGBD Sensor (Microsoft Kinect/Asus Xtion). The space in the room is processed by a PC running an application to determine the current ‘activity’. Wireless robotic lights are strategically placed around the room; each with a 2-servo system and standalone Arduino. The PC sends out commands to each light with an angle for the two axis and the intensity of the light. The lights receive this command wirelessly via a 315MHz receiver, and the Arduino then ‘aims’ the beam according to the command.
This isn’t the first time we’ve seen [Ken’s] work; a couple of years ago we saw his extremely unique ‘real life’ weather display. The ‘Myra’ system is still a work in progress, so we can’t wait to see how it all ends up. Be sure to check out the video after the break for a demo of the system.
Very nice makes the remote control lights i’m building look a bit outdated! I look forward to seeing more of Ken’s work on Myra
It’s very clever, although I don’t like to have spot lights. I prefer a more diffuse light.
Thanks for your comment. I’m thinking of putting adjustable lenses on each of the lights to let them automatically decide to diffuse or focus depending on what you’re doing.
It’s likely far more energy efficient to just flood your house with fluorescent or LED lights. Not as much fun of course nor anywhere near as much of a technical challenge.
Exactly what I was thinking too. But his is a cool concept that could lead to something quite useful on day. Flood lighting in combination with a myra reading light would be great…
He is, at least, already starting with an LED spotlight.
The Fluorescent Lights would also do a number on your fabrics, photos, paintings or anything else not UV resistant.
The UV emission from ordinary fluorescent lights is tiny compared to that from sunlight.
While it might use more energy (especially with LEDs) to direct a light than to just light up the whole space, if you apply it to heating or cooling, you’ll almost guarantee a net energy savings. That’s especially true if you’re stuck with a house or apartment with poor insulation and can’t upgrade it. A 75W reflector incandescent bulb feels very warm directly in front of it, compared to 1000W or more for a common space heater. Even after adding 200W or so for an old, inefficient PC, you’re still way ahead.
When you take into account the power needed to run the Kinects; the PC; and steppers you may be right but even if you could get the overhead down it’s still be incredibly annoying and generally inhospitable to live with that kind of lighting all the time. Maybe you could compensate for that by having lower levels of LED light coming from multiple different “turrets” spread throughout the room but at some point you certainly would have negated any energy savings.
It makes far more sense to just do what the lighting industry is already moving towards. Switch to all LED (since most other forms of lighting, especially fluorescent, don’t like to be turned on an off really fast or don’t dim well) and then us a combination of motion sensors and ambient light sensors. The motion sensors turn the light off as soon as there isn’t anyone in the room and the ambient light sensors detect how much, if any, light is coming in from windows and dims the lighting automatically to maintain a set light level without wasting energy.
Very impressive indeed. Nicely done, even in prototype form.
I’d rework it to watch my yard and track people with spot lights. Much more of a deterrent than just saying” you are being recorded”
Brilliant. I would set a standby position for each light for example to project to the ceiling to create a diffused light. So when you walk into the room all lignts turn projecting to the ceiling to create and ambient light. After you change activity (for example start reading) the best position light turns to your location and after some time all other light slowly fade away. That would probably result a smoother transition.
How your system behaves if more people more around the room?
Thanks for your advise. Yeah, I really need to learn interior design at some point…
Very good idea, I’ll try that.
The system recognizes multiple people, and assigns the lights to each person to accommodate as many people as possible.
now 3D print this model (incl. servo mounts) and it will look even more awesome :
http://www.thingiverse.com/thing:61796
Absolutely brilliant.
Would this scale easily to carry an IR heat source? I saw a TED video recently of someone who suggested such lights to warm people instead of the entire environment. This would be perfect.
Heh, found where I saw it:
http://hackaday.com/2013/12/16/a-new-way-to-heat-people/
Thanks for the pointer. Very interesting article.
As you say, I think one of the next steps Myra can take is scaling to other media; lights, heating, sound, smell, etc…
There may be a few extra challenges in optimizing heating, as it may involve simulating thermal dynamics on the fly.
Does Myra also tell the person to “Sit the hell still”?
When I seen this the first thing i thought was “this needs a glados case made for it.” Might be a bit creepy walking into a room and seeing multiple Glados “clones” watching you though.
Creepy? Only if they’re all pointed at the centerpiece of the room: the Portal Gun. As soon as you lift it up, they start tracking you while saying “The cake is not a lie.” Me? I’d just walk in eating cake and flip them all the bird. Take that GLADOS.
Sounds like the spotlights in Rendezvous with Rama.
Yes!
What if you are using a tablet, it’ll say ‘oh, the person needs glare on his screen, looks like a book’
But anyway, it’s a nice project and no doubt you learn a lot from it, but the last thing I want is a camera in my room. And a constant tracking combined with a lot of noise would also not please me.
But out of curiosity, what if there is more than one person?
The system knows the direction you’re looking at, and the surface normal of the book.
The current setup tries to assign a light that has a direct path to the pages of the book, without the lights going directly into your eyes.
Your point is a very valid point, and I should change my algorithms so that the system tries to consider surface glare as well.
Thanks for the advise.
As written above, if there is more than one person, the system recognizes this and assigns the most appropriate lights to each person.
I couldn’t show that in the video because my wife didn’t want to go on Youtube :)
the cake is a lie
I feel like a negative nancy pointing this out but;
The whole set up consumes alot more energy than full lighting to the whole room.
great project. the motion tracking is superb. well done!!!
Security lights and cameras might be the best use for something like this. Task lighting not so much.
