A Do-It-Yourself Air Conditioner With Evaporative Cooling 5 Gallon Bucket
image42-300x225The people over at Gray Wolf Survival have this amazing little air conditioning project that is a perfect addition to any household that doesn’t have flowing air wafting through. It was created by [Figjam] for a trip to Burning Man, where all kinds of crazy ideas are bred in the hot dry heat of The Playa sun.
The design uses no ice, which is the cooling agent typical found in other DIY air conditioners. Those generally cut holes in the top of a cooler, put a fan on top to blow the air down across the ice. This is similar, but acts more like an evaporative cooler (not really a traditional air conditioner but it does the job).
397648283-300x225It uses a LOT less energy than an air conditioner unit so there won’t be a need to increase the power capabilities of a simple system to work it, and it can reduce the temperature by up to 30 degrees as well as alleviate the dryness associated with living through a Burn. It runs off 12V DC so it can either use the solar panel or connect to a battery. It has a 12V power plug for this, and draws as little power as absolutely possible. Plus, it has the ability to easily connect to a larger water source so it won’t have to be continually refilled. These considerations make it very portable and perhaps backpackable as well.
[Figjam] took a 5 gallon bucket, wrapped the inside with two layers of swamp cooler matting, made a loop of hose above it connected to a submersible pump and ran a fan out the top with piping. Connecting it to a shelter is done with a vent hose.
Turning Street Sweeper Bristles Into Lock Picking Tools…For Science!
In between writing for Hackaday, most of us (if not all of us) like to design projects on our own, creating whatever might come to mind. I, for instance, enjoy experimenting with lock picking techniques at industrial, gritty, and real warehouses in Southern California learning how to utilize the resources there, turning spare parts into something completely different.
One such skill I learned is how easy it is to make lock picking sets from discarded scraps of metal. The documentation is found on a personal blog of mine called HackerTrips (we cover our own stuff sometimes). It contains several photos and descriptions of the process involved which I picked up thanks to a hackerspace in Fullerton where local makers dream up all kinds of interesting projects.
The project starts out by walking on the streets, which is a rarity these days. This is because the general modes of transportation now are either a car, a bus, a subway, a train, a bike, or a plane, which puts the attention on the destination at hand rather than peering into the fractures of the road. This means that a lot of the time, people don’t notice the hidden treasures found on the side of the street, including the street sweeper bristles that have been knocked off their edges.
Continue reading “Turning Street Sweeper Bristles Into Lock Picking Tools…For Science!” →
