Making Funhouse Mirror Lenses
[Robb] has had a little experience making lenses from scratch. His first attempt was for a DIY projector, and while the lens was a little blurry, it did work rather well for something carved out of a block of acrylic. Now he’s taking his experiments with lenses even further with DIY optics that turn everything into a funhouse mirror.
There were two techniques tested while making these lenses. The first was the old standby, CNC milling. A piece of acrylic was put in a CNC and carved with a 1/2″ ball mill. The second technique was 3D printing on a very fancy and very expensive Objet Connex 500. Neither of these methods produce a ready to use lens; to get a finished lens out of the machined or printed objects, [Robb] had to wet sand with 240, 320, 400, 600, 1000, 1500, and 2000 grit sandpaper. After a few hours worth of sanding, the parts were polished with a scratch remover.
Making a lens like this isn’t really that novel – it’s basically the same way lenses have been made for 500 years. The real trick here is making funhouse mirror style lenses. These lenses were created by raytracing in Rhino and Neon. It’s tricky; the index of refraction for acrylic is a little lower than glass, and the refraction for 3D photoresin is a bit higher than glass.
With those models in hand, it’s a relatively simple matter of making some very cool and very strange lenses.
7 thoughts on “Making Funhouse Mirror Lenses
  1. Would printing on the Objet in “gloss” mode have helped alleviate the need for some of the polishing? At least on one side?
    1. Not really. The Objet leaves layers and streaks in the finished part. Even on brand new print heads the print is never perfectly smooth.
      The other issue with the objet l is that the resin lines never get perfectly clean between material changes. So some color is mixed into the clear until a large amount of material is passed. The Vero clear also tends to discolor under the uv lamps. Running in high speed will fix some of that.
      For a really clear lense go for SLA. We use SL 7870 resin, which prints very clear lenses. A bit of polishing there would produce a better lense than the Connex.
  2. If it is thermo set plastic a heat source a bit cooler than melting point works well for polishing after getting the lumpies out.
Leave a Reply to WaterjetCancel reply
