Fidget spinners were the hottest new craze at one point, but their 15 minutes of fame has well and truly passed. They’re great for fidgeting, and not a whole lot else. One of the main objectives around their use is to spin them as quickly as possible. After [Sushi Ramen] hurt himself after spinning one up with compressed air, however – a new and dangerous idea came to mind.
What you’re looking at is a fidget spinnerĀ sword, powered by compressed air. That alone is somewhat of a blessing, as it prevents this horrifying device from being easily man-portable. Through a breakneck build montage, we see almost fifty fidget spinners (in hyperchrome, no less) mounted to a shaft. The shaft is then attached to a hilt and a plastic line is artfully bent up to deliver compressed air at the pull of a trigger, causing the fidget spinners to rotate at moderate speed.
It’s true that the fidget spinners don’t receive a whole lot of torque from the compressed air and thus most of the damage is done purely by swinging the presumably quite heavy device at fragile glass objects. That said, with nothing ventured, nothing is gained, and we’re always glad to see research and development continuing in the fidget spinner space.
Looking for more effective ways to spin, and spin quickly? Check out this brushless motor setup. Video after the break.
