Step ‘n Snack Fanny Pack Motivates With M&Ms
[Sam March] has made a lot of different kinds of things, many of which have appeared on these very pages. Nowadays he wants to get the viewers more involved in his projects, so he started doing a monthly collaboration with YT viewers. Basically, he gives a prompt, and people comment with their wild and crazy ideas on the topic. Whoever has the winning idea gets the finished build. The maiden prompt was ‘fanny pack’, and you can check out the result in the build video (embedded below).
Someone suggested a Reese’s cup-dispensing fanny pack that gives you one cup for every 10,000 steps you take. We like what [Sam] did with that idea, because it’s way more practical — M&Ms are the original travel candy, and this way, you get to eat chocolate way more often. Depending on your sweet tooth, Reese’s Pieces would be a good compromise.
[Sam] figured out that the average human burns one calorie for every 25 steps, and that the average plain M&M is worth four calories, so he built a fanny pack with a step counter that dispenses one M&M for every 100 steps taken using a tiny auger. It’s calorie-neutrality!
You might be wondering if [Sam] made the fanny pack, too, or used something store-bought. The answer is neither: at some point in the build process, a company graciously offered to make a fanny pack with a special compartment in the bottom for the M&M dispenser. If you want to build one of these for yourself, you can get the CAD file for the milled base, the screw, the hopper, and the lid plus the code and also the gerbers on GitHub. We see a place for the sewing pattern, but as of now, the folder is empty. Be sure to check out the build and demo video after the break as [Sam] hits the town in a screaming set of neon workout wear to test the dispenser.
Most of the M&M-based projects we see around here are designed to sort by color. Here’s one that searches for the holy grail — peanut M&Ms that didn’t get a peanut.
5 thoughts on “Step ‘n Snack Fanny Pack Motivates With M&Ms
  1. There’s two types of motivation: extrinsic and intrinsic.
    People exercise because of intrinsic motivations, not because of extrinsic rewards. When you use extrinsic rewards to influence behaviour, it replaces the intrinsic motives, and this is called the “overjustification effect”.
    https://en.wikipedia.org/wiki/Overjustification_effect
    Extrinsic rewards get adapted to over time, so that over time those same extrinsic rewards don’t motivate as much, and eventually don’t motivate at all. This is called the hedonic treadmill, and implies that either the rewards need to be increased over time, or the motivating will fade.
    https://en.wikipedia.org/wiki/Hedonic_treadmill
    So in effect, rewarding yourself for exercising in this way will, over time, kill your motivation for exercising. It’s the wrong type of reward for this type of activity.
    You need intrinsic rewards for exercising: choice of what to do, a feeling of accomplishment, progress over time, learning something new, and personal benefit.
    Focus and enhance those aspects and you will enjoy exercise and continue to get the most benefit from it.
    I’m currently making a sort of program that people can use to enhance motivation for doing projects, and exercise is one of the project types my program addresses. It’s here if interested:
    https://hackaday.io/project/180726-motivation
  2. Kristina, I have trouble reading your articles because of all of the abbreviations and slang. What’s a YT viewer?
